Unified Computing System Knowledge Base
Knowledge Base Articles
The following Cisco UCS Platform Emulators are available for download from Cisco: Current Cisco UCS Platform Emulators CONFIGURATION IMPORT NOTE:  Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) ...
ericwill by • Cisco Employee
  • 614646 Views
  • 138 comments
  • 137 Helpful votes
A Field Guide covering the installation and initial configuration of Cisco Compute Hyperconverged with Nutanix systems using Intersight Managed Mode for Cisco UCS Unified Edge servers. Intersight Managed Mode (IMM) is the term for Cisco Unified Edge ...
beveritt by • Cisco Employee
  • 3000 Views
  • 0 comments
  • 3 Helpful votes
A Field Guide covering the installation, configuration and integration of the Cisco UCS X580p PCIe Node into a Nutanix cluster running on Cisco UCS X-series Modular Servers. The Cisco UCS X580p PCIe Node, plus the associated X9516 X-Fabric modules an...
  • 3063 Views
  • 0 comments
  • 1 Helpful votes
Beginning with Cisco IMC 3.0, standalone Cisco UCS servers can be managed through a Redfish API.  Redfish is an industry standard management interface based on the Open Data Protocol (OData) RESTful API specification.  Many common management tasks ca...
dsoper by • Cisco Employee
  • 12962 Views
  • 1 comments
  • 2 Helpful votes
To ensure the correct installation process is being followed for Cisco Compute Hyperconverged with Nutanix, please refer to the following flowchart to choose the correct documentation for the system being installed:    This document covers the ISM de...
  • 63270 Views
  • 21 comments
  • 16 Helpful votes
****UPDATE July 2021   The HUU images launched with our C-Series M6 Rack Servers are now compatible with the following USB creator toolsets:   Tool name Tool link  Supported on Windows Supported on Linux Supported on Mac  UEFI mode UEFI secure mode L...
One of the unappreciated features of the Cisco C-Series server is the ability to carve up the VIC into multiple virtual adapters.   This allows you to apply things like jumbo frames and COS to adapters on the same physical link.  It also makes dealin...
To ensure the correct installation process is being followed for Cisco Compute Hyperconverged with Nutanix, please refer to the following flowchart to choose the correct documentation for the system being installed:    This document covers the UMM de...
  • 29707 Views
  • 2 comments
  • 11 Helpful votes
Top Contributors
