cisco ucs c220 m4 how can i boot with the cisco sas 12g controller ? UEFI server 2012 installation issues
tian chen
first time with cisco ucs c220 m4 ,check my pictures
50 Replies 50
no advanced tab in boot options , check my picture
Try setting the Configured boot mode to UEFI, reboot, and come back and set it to Legacy, reboot, and check.
Also, noticed you have the onboard software raid also enabled.  Go into the bios, advanced settings in CIMC, and disable the 'SCU' option.
Also, need to make sure you don't have 4K sector drives.  If you do, then you will need to use UEFI boot setup.
Kirk...
sorry cant find SCU option in CIMC
Pulling my hair right now, having the same issue. Attached is the screenshot of my settings.
take note, i have MRAID instead of HBA. Can someone please help?
tian chen
so many thanks, booting after os installed,  the windows boot manager showed in boot order,  it works.
