Find power consumption
SamUrai
I want to find the total power consumption of an UCS server ( UCS managed and standalone) from within RHEL  and from FI.
Can someone advise on that? Thanks
Enes Simnica
hello @SamUrai. To check UCS server power usage from RHEL, use #ipmitool dcmi power reading if BMC access is available. U can also query the Redfish API with curl if supported, or use Cisco-provided tools if installed.
On the UCS side, in managed mode, use #show server power id or #show power-stats in the UCS CLI. The UCS Manager GUI also shows power under Equipment > Servers > Server > Power Monitoring. For standalone servers, connect to CIMC and run #show power... also check these links:
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Enes Simnica
-Enes
more Cisco?!
more Gym?!
