How to retrieve power usage information on CIMC using XML API
Eriko Yahata
Hi, experts
Is it possible to retrieve current power usage information on CIMC using XML API?
If yes, what is the dn?
Can I see it through Visore?
Cisco UCS Rack-Mount Servers CIMC XML API Programmer�s Guide - The CIMC Visore Utility [Cisco Integrated Management Cont…
--------------environment--------------
UCS C240M3
CIMC:1.5(4)
thank you in advance!
Jeffrey Foster
Hi Eriko,
This PSU Input (Wattage) is not available through the XML API currently. This information is available via the WebUI, the CLI and IPMI. It is something under consideration for inclusion with a future release. Please reach out to me directly if you have any follow-on questions. Cheers!
Jeff Foster
Jeffrey Foster
Hi Eriko,
Jeff Foster
Hi, Jeff
Thank you very much for the prompt reply
This information helps me a lot!
Eriko
