Hyperflex DataPlatform 4.5 List Index Out of Range (Standalone FI)
Markus5849
We have a standalone FI 64108 and are trying to deploy hyperflex cluster using HXDP 4.5 (2a). However, we're getting error "list index out of range". Before that when we deploy with a pair of Fabric Interconnect cluster there's no issue but when we switch to standalone mode then we hit below error.
May I know if Hyperflex DataPlatform supports standalone FI deployment?
Chris is correct.
The index out of range message is a funny way of saying your vnic count (both side A and B) is off because they are not up.
HX standard cluster does not support single FI, and your install workflows will fail.
Kirk...
Mark Elsen
          - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvt43652
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
RedNectar
Hi @Markus5849 ,
I'm not sure what you mean by "standalone FI deployment" - but if you mean "Can you install HyperFlex without providing L2 connectivity between the FIs (via a switch/switches)?" then the answer is NO
To successfully deploy HX on a FI platform, you MUST provide this connectivity.  I tried one (to pre-deploy in readiness to connecting to upstream switches which had not arrived yet) and discovered that it didn't work.  However, I don't know if that relates to the specific error you mention.
RedNectar aka Chris Welsh.
Chris is correct.
Kirk...
