Increase of priority flow control counters in a FCoE environment
ovm
I need some input about what is normal in a FCoE environment in regards to priority flow contol counters.
I see Increase of RxPPP and TxPPP counters on a FCoE end to end enviroment. however we don't see high traffic rates to/from storage array(<1Gbps). Customer have not reported low transfer from storage.
Setup:
CNA hosts - FEX2232 - N5K - EMC-VNX
FCoE end-to-end, No native FibreChannel.
CNA adapters = Emulex.
Is a problem I should look further into or is it normal?
I have read the troubleshooting guide.
http://www.cisco.com/en/US/partner/docs/switches/datacenter/nexus5000/sw/troubleshooting/guide/n5K_ts_fcoe.html
some output:
N5K-2# sh inter priority-flow-control
Port               Mode Oper(VL bmap)  RxPPP      TxPPP
FEX101-2232 1-8
Ethernet1/1        Auto Off           0          211994
Ethernet1/2        Auto Off           0          0
Ethernet1/3        Auto Off           2891830    0
Ethernet1/4        Auto Off           6269410    0
Ethernet1/5        Auto Off           12109662   0
Ethernet1/6        Auto Off           79534      0
Ethernet1/7        Auto Off           0          0
Ethernet1/8        Auto Off           0          0
FEX102-2232 9-16
Ethernet1/9        Auto Off           0          9994780
Ethernet1/10       Auto Off           0          0
Ethernet1/11       Auto Off           24678      0
Ethernet1/12       Auto Off           0          0
Ethernet1/13       Auto Off           4316       0
Ethernet1/14       Auto Off           136        0
Ethernet1/15       Auto Off           0          0
Ethernet1/16       Auto Off           0          0
!VNX-FCOE-ATTACHED SP_A
Ethernet1/19       Auto On  (8)       1888566    10100200
Ethernet1/20       Auto On  (8)       10414603   1367098
Ethernet1/23       Auto Off           0          0
Ethernet1/24       Auto Off           0          0
Ethernet1/25       Auto Off           0          0
Ethernet1/26       Auto Off           0          0
Ethernet1/27       Auto Off           0          0
Ethernet1/28       Auto Off           0          0
Ethernet1/30       Auto Off           0          0
Ethernet1/32       Auto On  (8)       0          0
Ethernet1/38       Auto Off           0          0
Ethernet1/39       Auto Off           0          0
Ethernet1/40       Auto Off           0          0
Ethernet1/41       Auto On  (8)       0          0
Ethernet1/42       Auto On  (8)       0          0
Ethernet1/43       Auto On  (8)       0          0
Ethernet1/44       Auto On  (8)       0          0
!CNA atttached hosts.
Ethernet101/1/1    Auto On  (8)       37109      33155
Ethernet101/1/2    Auto On  (8)       120        32336
Ethernet101/1/3    Auto On  (8)       274        34404
Ethernet101/1/4    Auto On  (8)       1924       64754
Ethernet101/1/5    Auto On  (8)       144        14684
Ethernet101/1/24   Auto On  (8)       4296788    4466
Ethernet101/1/25   Auto On  (8)       104520     22
Ethernet101/1/26   Auto On  (8)       838        30824
Ethernet101/1/27   Auto On  (8)       796        7770
Ethernet101/1/28   Auto On  (8)       13749152   1684
Ethernet101/1/29   Auto On  (8)       5912918    1276
Ethernet101/1/30   Auto On  (8)       3296026    2292
Ethernet101/1/31   Auto On  (8)       0          80
Ethernet101/1/32   Auto On  (8)       0          0
Ethernet102/1/1    Auto On  (8)       75656      323512
Ethernet102/1/2    Auto On  (8)       0          5632
Ethernet102/1/3    Auto On  (8)       4278       173828
Ethernet102/1/4    Auto On  (8)       0          0
Ethernet102/1/28   Auto On  (8)       2872       300046
Ethernet102/1/29   Auto On  (8)       28216      11808124
Ethernet102/1/30   Auto On  (8)       4792       441340
Ethernet102/1/31   Auto On  (8)       0          0
Ethernet102/1/32   Auto On  (8)       1040       201214
Just a one of the servers
GDC-CORE-SW04# sh inter e101/1/29 priority-flow-control
Ethernet101/1/29   Auto On  (8)       5912932    1276
GDC-CORE-SW04# sh inter e101/1/29 | in pause
    0 Rx pause
    0 Tx pause
Ethernet101/1/29   Auto On  (8)       5913378    1276
GDC-CORE-SW04#
    0 Rx pause
    0 Tx pause
VNX
GDC-CORE-SW04# sh inter priority-flow-control | in Ethernet1/19 ne 1
Ethernet1/19       Auto On  (8)       1889064    10100536
Ethernet1/20       Auto On  (8)       10414603   1367164
GDC-CORE-SW04# sh inter e1/19 | in "input rate"
  30 seconds input rate 133346744 bits/sec, 16668343 bytes/sec, 10762 packets/sec
    input rate 96.22 Mbps, 8.31 Kpps; output rate 118.68 Mbps, 8.83 Kpps
GDC-CORE-SW04# sh inter e1/20 | in "input rate"
  30 seconds input rate 36024752 bits/sec, 4503094 bytes/sec, 2342 packets/sec
    input rate 33.96 Mbps, 2.09 Kpps; output rate 24.95 Mbps, 1.50 Kpps
0 Replies 0
