ISR-WAAS and vWAAS TCP connection limit reached
Jaco Zandberg
With Cisco WAAS Appliances (WAE/WAVE) when the TCP connection limit of the device is reached, all new connections will be passed-thru without being optimized.
What is the behaviour with ISR-WAAS and vWAAS(on UCS-modules) when the TCP connection limit reached?
Jaco Zandberg
Response from Cisco TAC on this question,
"The behaviour for all WAAS platforms be it vWAAS or ISR-WAAS remains the same and if the WAAS instance hits its connection limit , then all the new connections will be pass – through and will not be optimized."
