Need help for setup VM-FEX on UCSM 2.2(1b)
MENG YUAN HSIEH
Hi expers,
I try to setup VM-FEX on FI6120 with version 2.2(1b). And vCenter and vSphere running on the version 5.5.
The extension plug-in can success add-on. But when I setup VMware Integration it always failed and show "extvmmProvider: connot contain: object of class vnicProfileSet with RN profile, DN is" as image in the below.
So I try to setup by CLI. But still failed. And event show estabished connection with vCenter failed.
Please help me to setup VM-FEX.
BTW. I only have one FI6120 can test VM-FEX. Is it a problem?
Best regards,
Meng-Yuan Hsieh (Nick)
You can still use the GUI guide, just do the stuff in Chapter 6 on configuring distributed virtual switches in cisco ucs.  It just separates the task into 3 items.  1. Create the Datacenter, Folder, and DVS.  2. Create a Port Profile.  3. Create a Profile Client.
6 Replies 6
rgzoso211
Did you ever get past this?
MENG YUAN HSIEH
Not yet.
I got it working without the wizard.  Seems to be working fine.  Just follow the manual for doing it step by step.
Yes! You are right! This version must manual to doing it step by step. The wizard is not work. Thank you very much!
