UCS Blade B200M3 - KVM does not respond to keyboard input.
I.Trankolov
New install 4 blades. 3 of them are working fine KVM Keyboard is ok. On one of them there is no keyboard input translated to the blade when using KVM. Please advice.
9 Replies 9
Walter Dey
Does this blade have a CIMC IP address ? and if yes, can you ping it ?
If above is the case
I would try to do a CIMC restart, KVM restart !
It does have IP, it is pingable and i have tried:
CIMC restart
KVM reatart
CMOS reset
Blade reseating and re-ack.
Please post UCS Version, BIOS, CIMC Version; which I/O adaptor and Version, of the server that fails, and one which is working ?
UCS version 2.2.3d. All firmware are the same bundle version. I/O: VIC 1240
Strange ! did you see any error message ? syslog ?
open a TAC case !
No errors in UCS Manager. In CIMC SEL log however there is an error that says no keyboard detected.
Please post the exact error message ! might really be a hardware issue ! you already did all the investigations ! don't waste more time and open a TAC case.
I've requested RMA already. Currently I am just digging on to it. Cannot post the error now. I will try later.
I am having this exact same issue with B200 M4 blades in a UCS Mini. 4 total blades, 3 are fine but 1 will not respond to keyboard inputs through KVM. The firmware is at 3.0(2d). The built-in macros in the KVM viewer for the function keys do not work as well. Please advise.
