UCS Nexus Best Practices
abbasali5
I have a customer who have (2) Cisco Nexus 5500UP connected to a pair of Fabric Interconnects.  Each 5500 connectes to both FIs with VPC.  They also have Fabric Interconnects cross connected which I don't see in any Cisco best practices docs.  Is there an advantage of this?
In this Layer 3 configuration, When they tried to uprade 5500 NX-OS, each at a time, it brought everything down.  Not sure, if this happened because of the fact that the Fabric Interconnects are cross connected.
Please advise!
Walter Dey
Have a look at Fig 11 in
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/white_paper_c11-623265.html
It refers to N7k, but it will apply to N5k as well.
Properly done, N5k should not be a single point of failure; you can do firmware upgrade without disruption of the UCS traffic.
Did you check, that the UCS FI mode is: Ethernet End Host Mode (EHM), which is the default ?
In this mode, the link between the 2 FI's is never used for data traffic.
