UCSM Issue
taksourabh
Hi Team,
I have an issue currently where when trying to login to UCSM it doesn't go through and it stucks at fetching required data.
I am using UCSM verison 3.1(1h), if anyone saw that issue and help here.
I have attached the screenshot too.
Kirk J
Greetings.
Can you test the HTML5 version?  It looks like this is the Java based version that is hanging up.
Does this happen on any workstations trying to use the Java based UCSM manager?
Please confirm if you have attempted to run the Java UCSM manager from other workstations, and the Java versions installed on them.
Kirk...
Thanks Kirk,
Correct its the java based which is failing i have tried it from different systems but no luck java version used 7 & 8.
I can confirm html version is working fine.
Hi Kirk/Team,
Any input on java based UCSM , thanks.
