beveritt
A Field Guide covering the installation and initial configuration of Cisco Compute Hyperconverged with Nutanix systems using Standalone Cisco UCS C-Series servers managed by Cisco Intersight. This guide is intended for technical training and educational purposes, for all who wish to install Nutanix on Cisco UCS based hardware following our supported hardware and software integrations and compatibility lists.
As a reference guide, the document presents our best practices and recommendations as of the time of publishing, and will be updated periodically. Please refer to the document history at the beginning to ensure you are using the most current version available.
The current document version is v1.1, which adds information regarding the deployment of Witness VMs for 2-node clusters, additional information regarding deployment of Prism Central on ESXi clusters, and several other minor updates.
mteixeira
Thank you for this doc.
Magical! Great guide. I've just deployed (for three months running) a small Intersight non-managed cluster at a customer in Sweden, and with the ACI plugin to AHV. It's been a bit of a mess, versions wise. This gives a bit of hope. Looking forward to the "in two months" releases!
