ericwill
Cisco UCS Platform Emulator, Release 2.2(2cPE1)
New Hardware Features
Cisco UCS Platform Emulator, Release 2.2(2cPE1), adds support for the following new hardware:
  • New scalable M4 Blade Module for the UCSC-B260-M4 or UCSC-B460-M4 Blade Server added
  • New rack-mounted server UCSC-C460-M4 added
  • Support for the following storage accelerators:
    • UCSB-F-LSI-400S
    • UCSB-F-LSI-800M
    • UCSB-F-FIO-785M
    • UCSB-F-FIO-365M
New Software Features
Cisco UCS Platform Emulator, Release 2.2(2cPE1) includes the following new features:
  • Support for the scriptable vMedia feature to create mount points on Cisco IMC. The mounts are only configured and not actually mounted.
  • New tab Storage Controller added under Startup Inventory. You can drag and drop the storage controllers on the rack-mounted servers or the blade servers.
  • You can add the scalable M4 Blade Module in scaled (4S) or non-scaled (2S) mode.
  • The default configuration is changed to the M3 blade and rack-mounted servers.
NOTE: From UCS PE 2.2(1bPE1) onwards, UCS PE supports uploading the B-Series and C-Series server firmware bundles.  Because of the large file sizes of the firmware bundles, UCS PE only supports uploading of only the stripped-down versions (attached to this document), which includes only the firmware metadata but not the actual firmware itself in the binaries.  The stripped-down version of the firwmare bundles which contain metadata only of the B-series and C-series server firmware is reduced to approximately 50 kB in size.
rinnor_chu
Community Member
HI, Eric
I downloaded the non-ova version and was very easy to import it into my vmware workstation 9 without any problem. So far, from my side is that the .ova version doesn't work fine and maybe need a further testing on your side within VmWare workstation context.
shasridh
Yes, we are aware there is an issue while importing .ova into VMware workstation. We are looking into it.
Sharan Sridhar
jerryu168
Community Member
Any plan to switch away from IDE controller for the four VMDK disks?   Customer experience with the emulator will improve quite a bit, if disk performance can be improved this way.
I run the emulator as a virtualbox vm and often feel that it can use some performance booster for API access and for UCSM access. My host is macbook with not-so-shabby spec (OS X  10.9.4, i7, 8GB DDR3, SSD, etc.).
Various modern hypervisors offer (much) faster SATA or SAS controller as disk controller options.
Excerpts from UCSPE.vmx in Cisco_UCS_Platform_Emulator_2.2.2cPE1.zip
ide0:0.present = "TRUE"
ide0:0.fileName = "UCSPE.vmdk"
ide0:1.present = "TRUE"
ide0:1.fileName = "UCSPE-0.vmdk"
ide1:0.present = "TRUE"
ide1:0.fileName = "UCSPE-1.vmdk"
ide1:1.present = "TRUE"
ide1:1.fileName = "UCSPE-2.vmdk"
cwalshscc
I am trying to import into fusion 7 & i get the error "SHA1 digest of file Cisco_UCS_Platform_Emulator_2.2.2cPE1-disk1.vmdk does not match manifest"
Can you assist with this issue?
Colin
