on 03-27-2015 07:45 PM
Cisco UCS Platform Emulator, Release 3.0(2cPE1)
CONFIGURATION IMPORT NOTE: Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) to physical UCS Manager domains is not recommended or supported by Cisco TAC. UCSPE backups should only be imported to UCSPE domains.
The UCS Platform Emulator version 3.0(2cPE1) is a platform release that ONLY supports the 6324 Fabric Interconnect based domains. No other Fabric Interconnect (6100 / 6200) will work with this UCSPE.
New Hardware Features
Cisco UCS Platform Emulator, Release 3.0(2cPE1), adds support for the following new hardware:
– Modifications to the VM Console login
– Modifications to the VM Console Options Menu
– Modifications to the Network Settings
– Modifications to the System Settings
– More details added to the Status Summary display
Known Limitations
Cisco UCS Platform Emulator, Release 3.0(2cPE1) has the following limitations:
NOTE: From UCS PE 2.2(1bPE1) onwards, UCS PE supports uploading the B-Series and C-Series server firmware bundles. Because of the large file sizes of the firmware bundles, UCS PE only supports uploading of only the stripped-down versions (attached to this document), which includes only the firmware metadata but not the actual firmware itself in the binaries. The stripped-down version of the firwmare bundles which contain metadata only of the B-series and C-series server firmware is reduced to approximately 50 kB in size.
Hi Team,
Please HELP..!!
I am UNABLE to download the UCS emulator the download gets terminated after few minutes.
Regadrs
JS
Reach out to me directly at ericwill at cisco dot com.
Eric
Dear Eric,
Can you please share with me Cisco UCS emulator as I am unable to download it from cisco website, the download get terminated after few minutes.
ThanksJS
Hi Eric,
I did sent u an email, you relied to me but did not share the link or method to download the Emulator...
Waiting for your response..
Hi All
Can any body upload the ova on 4shared.com or any similar sites
i am exhausted trying download UCSPE
and every time i receive several MBs and download process stop
I am getting "Failed to deploy OVF package .." Not sure what I am doing wrong. Please i need help
Please HELP..!!
Eric
Dear Eric,
I tried to download many times but failed, i sent you an email at ericwill@cisco.com . Please help.
best regards,
Tried to download. Failed. Help.
having similar problem, my download stop at 94.9Megs..
does anyone have alternate download link??
Please send email to Eric so that he can share his Dropbox link with you.
best regards
On Mon, Oct 19, 2015 at 8:57 AM, nur fahmi hamdika <community@cisco.com>
I cant download it and I email ericwill but no reply can anyone help
it goes to download but archive file is damaged or corrupted :/
I cant download, How to download this file correctly
