The UCS Manager XML Schema forms the basis for the UCS Model Driven Architecture.
The UCS PowerTool and UCS Python SDK are all code-generated, based on the UCS Manager XML Schema.
Attached below are all the Schema and Schema Diffs that have been published since the 1.4(3q) release.
Future Schema and Schema Diff files will be added to this list.
Added 3.1 Object Model files and the schema xsd files from the UCS PE.
Note that 3.2 schema files are currently a preview and official 3.2 files will be attached soon.
Dan Laden
is the 3.2 schema considered final at this time?
dsoper
