Attaching 2 vMedia images over network
avgovind
Using python script I need to mount an ISO image and a USB image to Cisco server IMC over network. Is it supported by Cisco IMC? The images are shared using HTTPS server.
I need to mount both ISO and IMG images same time so that when the server is booted into the ISO it can access the contents of IMG image which is mounted as vMedia USB.
This is supported by HPE iLO but not supported by iDRAC. I am trying to find out if CIMC supports.
Thank you in advance for your responses!
delgadm
Hi!
I checked with an expert and it’s possible. Just be sure the media type is unique for each media type. For example, ISO and IMG or HDD image is one valid combination.
Hope this helps!
avgovind
delgadm
Hi!
Hope this helps!
Thank you very much for answering my question. I am glad to know the Cisco servers support this feature.
