Issue with ODT script sending back to PVA
david-oldham
We have 2 FIs 5 Chassis and 37 Blades and 3 c220 standalone servers, but within Intersight PVA the HCL status for all blades but two running ESXI is Incomplete. This is due to ESXI blades using UCS Tools from VMware Cisco firmware bundle but the rest are running Red Hat Linux and as such should be using the ODT script from a Control Node Linux box to then query all other blades running Linux and return the OS state etc info back into the PVA to allow HCL for Software stage to be validated. I have only one blade running linux configured as a client of the odt control node so far its chassis 14 blade 6, But when odt script failed when run See attached document pdf for details of issue.
Note this blade is successfully discovered and claimed within our PVA, and if i query the PVA API directly via Name or Serial Number the blade is found and all relevant details are displayed.
david-oldham
Here is the api serach data one via name one via serial number
dsoper
If you can post an issue to https://github.com/CiscoDevNet/intersight-python-utils/issues and include your json config file the team can take a look at any issues using a PVA with ODT.
