Errors found during UCSM Configuration
Nuhu_20071
Dear All,
We are facing some issues with Hyperflex Cluster creation, below here are details
1) Download and activated the required firmware bundle.
2) Reset Fabric interconnect
3) Tried with different hyperflex installer like 4.0 a and 4.0 c
4) FI cluster are UP and NTP server reachable.
still problem exist ....
your prompt support  will be appriciated.
Regars
2 Accepted Solutions
Kirk J
You are missing the Blade (B) series bundle packages in the UCSM.  It looks like you have the 4.04 "i" version for UCSM and the C series, but have the 4.04 "L" version for the B/blades.
What ever version you are choosing in the installer drop down, make sure that both B and C series versions are present on the UCSM.
Kirk...
Dear Kirk J,
Good Day,
Thanks for your prompt support, Zooming in exactly shows the installed Package was 4.0 'l' ........updating with required 4.0 'i' solved the problem.
Nuhu
Kirk J
Kirk...
Dear Kirk J,
Good Day,
Nuhu
