timoma
Overview:
A virtualized server implementation consists of one or more VMs running as 'guests' on a single physical server. The guest VMs are hosted and managed by a software layer called the hypervisor or virtual machine manager (VMM). The hypervisor typically presents a virtual network interface to each VM and performs Layer 2 switching of traffic from a VM to other local VMs or to a physical interface to the external network. Working with a Cisco virtual interface card (VIC) adapter, Cisco Virtual Machine Fabric Extender (VM-FEX)bypasses software-based switching of VM traffic by the hypervisor in favor of external hardware-based switching in the fabric interconnect. This method results in a reduced load on the server CPU, faster switching,and the ability to apply a rich set of network management features to local and remote traffic. VM-FEX extends the (prestandard) IEEE 802.1Qbh port extender architecture to the VMs, providing each VM interface with a virtual Peripheral Component Interconnect Express (PCIe) device and a virtual port ona switch. This solution allows precise rate limiting and quality of service (QoS) guarantees on the VM interface.
Infrastructure Requirements
  • The host must be managed by Cisco UCS Manager Release 2.1 or later.
  • The host operating system must be an edition of Windows Server 2012 or later that includes Hyper-V support. For more information about installing Microsoft Hyper-V, see the Microsoft Windows Server documentation.
  • In the host BIOS Processor settings, you must enable Virtualization Technology (VT) and Direct Cache Access.
  • In the host BIOS Intel Directed I/O settings, you must enable VT For Directed I/O and Interrupt Remap.
  • For more information about configuring UCS server BIOS settings, see the Cisco UCS Manager GUI Configuration Guide.
  • HTTPS communication must be enabled on the Cisco UCS Manager. For more information about enabling HTTPS communication, see the Cisco UCS Manager GUI Configuration Guide.
  • One or more Cisco VIC adapters must be installed in the host. For more information about installing a Cisco VIC adapter, see the Cisco UCS 5108 Server Chassis Hardware Installation Guide.
  • An SR-IOV PF cannot be used as an iSCSI vNIC. An existing iSCSI vNIC cannot be defined as a PF.
VM-FEX Mode of Operations
Windows
Windows
VM-FEX Mode
Emulation
Hypervisor Bypass with SR-IOV
Minimum Hypervisor Version
Windows 2012
Windows 2012
Minmum ENIC Driver Version
UCSM 2.1(1a)
UCSM 2.1(1a)
Minimum VIC Firmware Version
UCSM 2.1(1a)
UCSM 2.1(1a)
VM-FEX Tool Pleaese refer to attachment Please refer to attachment
VMotion / Live Migration
SupportSupport
Support Guest OSAny OS support by Hyper-V
Windows 2012 only
VM-FEX Scalability
UCSM Configuration Limit 2.1 Release -http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/configuration_limits/2.1/b_UCS_Configuration_Limits_2_1.html
Cisco UCS 6100 / 6200 Series
Hypervisor
Half-Width Blade with Single VIC
Full-Width Blade with Dual VIC
ESX 4.0 – 4.1 (DirectPath I/O)
56 (54 vNIC + 2 vHBA)
ESXi 5.0 – 5.1 (DirectPath I/O)
116 (114 vNIC + 2 vHBA)
116 (114 vNIC + 2 vHBA)*
Windows 2012 (SR-IOV)
232 (228 vNIC + 4 vHBA)
KVM 6.1 – 6.3 (SR-IOV)
* Additional VIC will NOT increase the total VIF count due to OS limitation
* Multiple VICs are Supported for full width blade and B200M3
Video Configuration Demo Topology
Hyper-V VM-FEX Configuration Workflow
Video Link : 11298
Reference Documentation
UCSM Hyper-V VM-FEX GUI Configuratoin Guide
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/vm_fex/hyperv/gui/config_guide/2.1/b_GUI_Hyper-V_VM-FEX_UCSM_Configuration_Guide_chapter_010.html
UCSM Hyper-V VM-FEX CLI Configuratoin Guide
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/vm_fex/hyperv/cli/config_guide/2.1/b_CLI_Hyper-V_VM-FEX_UCSM_Configuration_Guide_chapter_010.html
Hyper-V VM-FEX Configuration Example - TAC
http://www.cisco.com/en/US/products/ps10281/products_configuration_example09186a0080c1780d.shtml
Cisco-Live-BRKCOM-2005-Virtual Machine Fabric Extension (VM-FEX)-2013
VM-FEX Configuration & Best Practice for Multiple Hypervisor
Please refer to the attachmenta
Cisco VM-FEX Performance Testing verus VMware vSwitch
http://www.cisco.com/en/US/solutions/collateral/ns340/ns517/ns224/ns944/whitepaper_c11-727581.html
External (Light Reading) VM-FEX Peroformance Testing verus VMware vSwitch
http://www.lightreading.com/document.asp?doc_id=693092
VM-FEX Performance Testing with SAP
http://www.cisco.com/en/US/solutions/collateral/ns340/ns517/ns224/ns944/whitepaper_c11_703103.pdf
VM-FEX Performance Testing with Microsoft SharePoint 2010
http://www.cisco.com/en/US/docs/unified_computing/ucs/UCS_CVDs/ucs_sharepoint2010_flexpod_vmware.html#wp402742
VM-FEX Performance Testing with Microsoft SQL Server 2012
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10281/whitepaper_c11-711915.html
VM-FEX Performance Testing with Citrix Xenapp 6.5
http://www.cisco.com/en/US/docs/unified_computing/ucs/UCS_CVDs/citrix_emc_ucs_XDXAscale.pdf
Microsoft Private Cloud Fast Track 3.0 with VM-FEX
http://www.cisco.com/en/US/docs/unified_computing/ucs/UCS_CVDs/ucs_flexpod_mspc30_sc12_deploy.pdf
Drwhorulez
Community Member
This page need to be updated to support Windows 2012 R2.
csco11542695
Surely! This page must update to support Windows Server 2012R2 64-Bit !!!!
We can't find VMFEX Tools newer version to install on OS Host.
