MRAID12G Performance Monitoring
SamUrai
Is there a way to gather the real-time statistics off this controller and fed them to Grafana on UCS Rack servers ( standalone or UCSM controlled )
Don't know if UCSM provides a way to gather the stats via SDK ?
Looking for solutions/methods out there for monitoring the controller I/O performance,
2 Accepted Solutions
Don't know of any out-of-band storage performance details provided by CIMC/UCSM.
As far as I know the OOB data is all inventory/PID/configuration/etc which wouldn't include performance details.
Would be better off getting these details inband from the OS installed.
The MRAID is a LSI controller so any LSI monitoring software should work.
Probably need to use storcli
from https://docs.broadcom.com/doc/MR-TM-StorCLI-UG
storcli / cx show dpm
This command shows the drive performance monitoring status on the controller.
Input example:
storcli /c0 show dpm
storcli / cx start dpm
This command starts the performance monitoring on the controller.
Input example:
storcli /c0 start dpm
storcli / cx stop dpm
This command stops the performance monitoring on the controller.
Input example:
storcli /c0 stop dpm
storcli /cx delete dpmstat type = HIST | LCT | RA | EXT | All
This command deletes the drive performance monitoring statistics of the controller.
Where:
• HIST – Historgram of response time.
• LCT – Long Time commands.
• RA – Running average drive statistics.
• EXT – Extended DPM information.
storcli /cx[/ex]/sx show dpmstat type = HIST | LCT | RA | EXT [logfile[=filename]]
This command shows the drive performance monitoring statistics of the mentioned drive.
• logfile – If the file name is not specified, it logs tostarsas.log or to a user-specified file.
Have always been told this should only be used for baselining, and troubleshooting, and to NOT just leave it running.
Kirk...
7 Replies 7
SamUrai
Anyone?
Thanks. The LSI software is probably an option as I read online that there is a flag to enable the stats with a performance penalty. However there is no documented procedure or details other than that.
I will contact Broadcom support.
Input example:
Input example:
Input example:
Where:
Kirk...
SamUrai
So I tried the "storcli" comand with dpm options but I get message which says "DPM feature is not supported"
This  MRAID12G is installed on C240 M5Sx box.
Ok it looks like DPM is compatible with 3Ware LSI controllers.
For MRAID12, I see the controllers supports "Performance Metrics = yes".  So I guess I've to install and check MSM software and figure out how to collect the performance stats.
SamUrai
Ok. The controller doesn't provides the performance stats by itself.  One has to use IOMeter or other similar tools.
