Need help formatting Cisco UCS B200 for Server 2008
This was an ESXi host that I want to setup as a physical Server 2008 R2 server. Where I get hung up is the Installer give me grief that the partition is GPT and can't do the Windows one. So I attached the Driver DVD for the Cisco UCS B200 M2 and it doesn't like any of those drivers. I can delete the partition and do a new but it always comes back as GPT.
thanks
Gary
padramas
Hello Gary,
What is the size of the installation disk ?
Did you try deleting and formatting the disks ?
Did you click refresh after loading the drivers ?
Can you please share the exact error message that you receive ?
Padma
I did not build the original server but it looks like several partitions were created. I will have to do more investigation on how it was setup. It probably had esxi installed on one of the smaller partitions and the one I was trying to install Windows on was probably the drives used for the datastore.
After I find out how it was built I will get back to here.
