UCS : monitor interface queue drops via SNMP
Thijs Van Severen
Hi all,
I'm trying to find the correct SNMP OID to monitor the interface queues of my 6248UP's
It is easy enough to check the dropped packets in the queue via cli :
KOR-J11-FI4-A(nxos)# sh queuing interface eth1/29
Pkts discarded on ingress : 128771804
But i need to get this value via SNMP and i just cant find the correct OID
According to this page there is 1 MIB that handles QoS : CISCO-UNIFIED-COMPUTING-EPQOS-MIB
But i just can find anything that links to the queue drop counter ...
Any idea's ?
Grtz
Thijs
I had the same response on my N5548 until I updated to 7.0(5)N1(1)
I am now getting a response and counter output at 1.3.6.1.4.1.9.9.166
I would expect to see this ported to the UCS at somepoint since it is now available in later N5K code.
Kirk...
Kirk J
Greetings.
I skipped through the UCSM related MIBs, and don't think that info is exposed to SNMP.
I think that used to the be case for N7ks, but more recent code seems to have something similar to what you are looking for.  See http://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.166 and http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/system_management/7x/b_5500_System_Mgmt_Config_7x/class_based___quality_of_service_mib.html  although this does not help your UCSM request :)
I can file an enhancement request, but frankly I just haven't seen any customer requests for it at UCSM level, which is usually what drives getting the new features/enhancements implemented.
Kirk...
Thanks for the feedback Kirk, i appreciate it !
I have gone tough the info you linked to and there are a couple of interesting objects like these :
CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropPkt64.285212681.285212682 = Counter64: 0
CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropPkt64.285212681.285212686 = Counter64: 0
CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropByte64.285212681.285212682 = Counter64: 0
CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropByte64.285212681.285212686 = Counter64: 0
CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropBitRate.285212681.285212682 = Gauge32: 0 bits per second
CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropBitRate.285212681.285212686 = Gauge32: 0 bits per second
However, none of these work :
If i do a walk on 1.3.6.1.4.1.9.9.166 i get 'object not found'
The 6248UP is based on a Nexus5k, but maybe there is a difference in SNMP capabilities ?
Unfortunately I currently dont have a N5k running so i cant verify
EDIT : just fired up a 5548UP (version 5.2(1)N1(2a)) and tried a walk on 1.3.6.1.4.1.9.9.166 > same result 'object not found'
It looks like this is a general N5k thing, not limited to UCSm
EDIT2 : did the same test on a nexus9k N9K-C9504 (NXOS: version 7.0(3)I4(5)) and here it works
Any ideas ?
Grtz
Thijs
Kirk...
Thanks for the update Kirk
I guess i'll just have to wait then
Do you know if there is a way that i can track this ?
Grtz
Thijs
