UC320 v2.3.2(6), getting ERR_SSL_FALLBACK_BEYOND_MINIMUM_VERSION
Pedro Macedo
In late November 2014, while I tried to connect to a UC320 with version 2.3.2(6) via the WAN interface, I got the following error on my Chrome Browser (I have a Windows 7 PC):
I looked at the Chrome forums (https://groups.google.com/a/chromium.org/forum/#!topic/security-dev/Vnhy9aKM_l4) and read that starting on version 39 (the one I have) SSLv3 fallback would be disabled.
Tried to connect with Firefox, all went fine for a couple of weeks until it stopped working. Same thing with Explorer v11 (I downgraded to v10, and it isn't working either); with IE, I do get the "Blue Screen" from the UC320, but never get the full page to enter User & Password (I have tried the Compatibility options without success).
I serve a large UC320 installed base and it is critical for me being able to do remote support. I still have some Windows XP PC's from which I can connect to the UC320's, but I need to do it from the newer PC's that I have.
Any ideas on how to fix this? Either Chrome, Firefox or IE flags to modify? Or any patches on the UC320?
Pedro.
Dramaturg7675
Hello Pedro,
I have the same problem on Chrome: "ERR_SSL_FALLBACK_BEYOND_MINIMUM_VERSION", however I tested another browser: Opera.
Opera did complain about the certificate, however I was able to skip that.
I get the following HTML output: http://paste.ubuntu.com/9691770/ HOWEVER the Flash does not load.
It seems to be an issue with the HTTPS of the UC320 itself, as it also does not work when connected directly to a LAN port.
Any updates from CISCO re: this issue? Were you able to solve it?
My humble idea: I am thinking to do a port forwarding Port 8081 to 192.168.10.1:80 - so I can access the HTTP interface, but this didn´t work. Maybe I did set something wrong in the port forwarding, but this might be a dirty fix.
I created a SR with the TAC and the workaround they suggest (and it is working) is to use Firefox version 32. You have to go to the "Tools --> Options --> Advanced --> Update" menu and disable the "automatic update" so it won't change to v 34.
We tried IE 10 and IE 11, tweaking the Internet Options to use only SSL v3 (disabling SSL v2 and all TLS options) but I haven't been able to make it work. I need to do further testings, but haven't had the time. Following is MIcrosoft a link the TAC provided, that discusses the issue:
https://technet.microsoft.com/en-us/library/security/3009008.aspx
The TAC is looking to see if the Developers will provide a patch for the UC320 firmware, but it doesn't seem likely. So I'll have to stick with Firefox v32 for the moment.
Pedro.
