2620 Static on Inbound and Outbound Calls
Jim Augherton
Running 12.2(15) static started appearing yesterday on all calls inbound or outbound. Dialing 4 digit IP - IP works fine. The static is only happening at one out of six locations. Really looking for a staring point to start troubleshooting.
Thanks Jim
umedryk
Level 5
Level 5
you could find the documentation here : go to www.cisco.com/techsupport, click on Guest, click on Product Support, Click on Routers and then select 2600 series routers and select 'Troubleshooting'. You will find troubleshooting on same.
