adding new E1 to NAS & PGW problem ?????? .................................
tareqrebhi
Dears all,
itried to add new E1 to my system but ss7 signal didn't come up, i attached my test commands and my PGW and NAS configurations, just i need to mention that now i have 2 E1s are running with no probles but when i add new E1 the problems appeared ..... any help please ?
NAS configuration:
controller E1 7/7
framing NO-CRC4
channel-group 0 timeslots 1
pri-group timeslots 2-31 nfas_d primary nfas_int 0 nfas_group 2
description Connection to International
interface Serial7/7:0
no ip address
encapsulation ss7
channel-id 2
interface Serial7/7:15
no ip address
encapsulation hdlc
isdn switch-type primary-ni2c
isdn incoming-voice modem
isdn map address . plan isdn type network
isdn rlm-group 2
no isdn send-status-enquiry
isdn negotiate-bchan resend-setup
isdn bchan-number-order ascending
no cdp enable
rlm group 2
protocol rlm port 3004
server PGW1
link address 55.55.55.50 source FastEthernet0/0 weight 1
ss7 session 0 address 55.55.55.50 7000 55.55.55.49 7000 session-set 0
ss7 mtp2-variant Bellcore 3
ss7 mtp2-variant itu 0
SUERM-number-octets 16
PGW configuration:
prov-add:DPC:NAME="dpc-inter",DESC="DPC of inter",NETADDR="1.1.2",NETIND=3
prov-add:SS7PATH:NAME="ss7p-jtc-inter",DESC="ss7 path to inter",MDO="ETS_300_356",CUSTGRPID="0000",SIDE="network",DPC="dpc-inter",OPC="tar-opc",M3UAKEY="",ORIGLABEL="",TERMLABEL=""
prov-add:LNKSET:NAME="linkset-inter",DESC="Link Set inter",APC="dpc-inter",PROTO="SS7-ITU",TYPE="IP"
prov-add:SS7ROUTE:NAME="ss7route-inter",DESC="ss7 route to inter",OPC="tar-opc",DPC="dpc-inter",LNKSET="linkset-inter",PRI=1
prov-add:NASPATH:NAME="naspath3-inter",DESC="Nas Path to AS5400 to inter",EXTNODE="as5400",MDO="BELL_1268_C2",CUSTGRPID="0000",SIGSLOT=0,SIGPORT=0
prov-add:C7IPLNK:NAME="cs7iplinktointer",DESC="cs7 link to inter",LNKSET="linkset-inter",SLC=0,PRI=1,TIMESLOT=2,SESSIONSET="cs7set1"
prov-add:IPLNK:NAME="nas-iplink3",DESC="IP link 3 to AS5400",SVC="naspath3-inter",IPADDR="IP_Addr1",PORT=3005,PEERADDR="55.55.55.49",PEERPORT=3005,PRI=1,IPROUTE=""
prov-add:nailedtrnk:name="4002",srcsvc="ss7p-jtc-inter",dstsvc="naspath3-inter",srcspan="ffff",dstspan="1",srctimeslot="2",dsttimeslot="1",spansize=30
thank you for any helping
BR,
0 Replies 0
