AS5350 supports SIP?
rcandeloza
hi,
I have a spare AS5350 that i wanted to use for SIP.
Do i need additional module for it to be able to support SIP?
mrdogantr
     Yu can use sip and h323 on AS5350.
http://www.cisco.com/en/US/docs/routers/access/as5350/software/feature/guide/UPfeapu.html#wp1015330
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
hth
Muammer
voice service voip
hth
Muammer
Just more info: SIP is running without those commands on there.  If you need VoIP on both legs (SIP in, SIP out; H323 in, SIP out; etc.) you use those.
SIP->POTS and POTS->SIP work without those commands. You just need SIP dial-peers created.
