Call Rejected error when Using CTI Port to call out
eddie.cebreros
I am using Cisco Call Recording feature that is enabled on a phone that has a CTI Port and number assigned to invoke a call recording session to dial out a Long Distance number. I used JTAPI tool to invoke a call and then used the CTI that was invoked by the BIB to dial a long distance number. The call leaves the phone and gets to the gateway (MGCP) with 2 T1 Pri's and in the debug I see this error:
KNOW Good call:
001679: *Sep 20 14:39:53.005: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x5069
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18395
                Preferred, Channel 21
        Facility i = 0x9F8B0100A1080201010201008400
                Protocol Profile =  Networking Extensions
                0xA1080201010201008400
                Component = Invoke component
                        Invoke Id = 1
                        Operation = CallingName
                                Name not available
        Calling Party Number i = 0x0080, 'XXXXXXXXX'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, 'XXXXXXXXXX'
001680: *Sep 20 14:39:53.009: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xD069
        Cause i = 0x8081 - Unallocated/unassigned number
001681: *Sep 20 14:39:53.097: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x506A
FAILED Call:
001685: *Sep 20 14:39:56.509: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x1DA8
                Standard = CCITT
        Channel ID i = 0xA98384
                Exclusive, Channel 4
        Calling Party Number i = 0x0183, '2678'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x80, 'XXXXXXXXXXX'
001686: *Sep 20 14:39:56.537: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9DA8
001687: *Sep 20 14:39:56.557: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x9DA8
        Cause i = 0x8295 - Call rejected
001688: *Sep 20 14:39:56.585: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x1DA8
001689: *Sep 20 14:39:56.593: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x9DA8
001690: *Sep 20 14:40:07.001: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x4200
Anyhelp appreciated.
0 Replies 0
