Calls not completing
knmezi
Please my calls are completing, call any one tell me why the calls are dropping by reading the errors below:
*Mar 25 07:42:43.843: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 66.98.180.77:5060;branch=z9hG4bK3b91b512
From: "4047881723" <sip:4047881723@66.98.180.77>;tag=as624c20a8
To: <sip:15672520826@72.244.194.141>;tag=19A0F4-225D
Date: Mon, 25 Mar 2002 07:42:29 GMT
Call-ID: 3e80140a6b1f1c0e16588bbd77c281a3@66.98.180.77
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 102 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=3
Content-Length: 0
Accounting=0, Call Id=32
*Mar 25 08:58:34.471: //32/505F91928016/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=16)
*Mar 25 08:58:34.475: //32/505F91928016/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Mar 25 08:58:34.475: //32/505F91928016/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
*Mar 25 08:58:34.539: //32/505F91928016/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x65B0C4F8, Tag=0x0, Call Id=32,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*Mar 25 08:58:34.543: //30/505F91928016/CCAPI/ccCallDisconnect:
ause=0)
*Mar 25 08:58:54.047: //30/505F91928016/CCAPI/cc_api_call_disconnect_done:
Disposition=-11, Interface=0x652CDEE0, Tag=0x0, Call Id=30,
a-vazquez
Level 6
Level 6
Following URLs should help you:
This url Speaks about Understanding FXO Disconnect Problem, this should help you:
http://www.cisco.com/warp/public/788/signalling/fxo_disconnect.html
Cisco Unity Express CFNA Does Not Respond With Cisco CallManager Express E.164 Transfer:
http://www.cisco.com/warp/public/770/fn29926.shtml
Understanding Inbound and Outbound Dial Peers Matching on IOS Platforms:
http://www.cisco.com/warp/public/788/voip/in_dial_peer_match.html
