Calltracker & Syslog
ddurand
Community Member
I implement calltracker on a AS5350, and configure logging commands to send the results of the calltracker to a syslog server.
Calltracker call-record verbose
But nothing appears in the console or in a syslog server.
Any idea...
Thank you in advance.
ArisCahyadi
Community Member
Maybe you can use this command :
aaa new-model
gw-accounting syslog
logging
you will see result like this :
voice-gw#
*Mar 22 00:50:08.750: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId
FC68C2F3 257511CC 80A4E637 AA2FE4B0, SetupTime *00:49:56.310 UTC Mon Mar 22 1993
, PeerAddress , PeerSubAddress , DisconnectCause 29 , DisconnectText temporary
failure (41), ConnectTime *00:50:08.750 UTC Mon Mar 22 1993, DisconnectTime *00:
50:08.750 UTC Mon Mar 22 1993, CallOrigin 2, ChargedUnits 0, InfoType 2, Transmi
tPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Thank you.
u.siegrist
Community Member
I had the same problem. Try to reboot (after writing the config of course). It worked (sounds strange i know , but it works).
