Configure Cisco 1751v - Router for IP Phone
mactej6228
Hello Everyone,
I am new to Cisco Voice, I want to configure a cisco router "model 1751v", for the Cisco IP phone to work. Can you provide me a procedure on how to configure this router? And what are the software that needs to be loaded on router's flash memory and software/Files that needs to be loaded on the TFTP server? If i already place this topology on the production network am I still need the TFTP server?
Tnx in advance, your response is highly appreciated.
File attached: Test Topology and Router's running config
Mark,
Chester Rieman
Hi - Do you have a CUCM?  If not, what are you using for call control.
What you inluded will not work with sccp phone loads - it might work with SIP, if you send the calls
to a SIP provider or to the fxo port, being sure to forward the needed digits.
If its a skinny phone, you will needed a callmanager or callmanager express(runs on a router) for dial plan and call control.
Hope this helps.
Hello Chester,
I don't know if CUCM is already installed on the router, so I just share to you the content of router flash:
# dir flash:
Directory of flash:/
    1  -rw-    17037148                      c1700-ipvoice-mz.123-14.T7.bin
    2  -rw-      129196                      P00307020200.sbn
    3  -rw-      680394                      P00307020200.sb2
    4  -rw-      128792                      P00307020200.bin
    6  -rw-     1045952                      cmterm_7920.4.0-02-00.bin
    7  -rw-      331101                      CP7902060000SCCP050124A.sbin
    8  -rw-      496521                      music-on-hold.au
    9  -rw-     1908762                      P00503010100.bin
   10  -rw-       49169                      S00104000100.sbn
   11  -rw-      333822                      P00403020214.bin
   12  -rw-       47904                      S00103020002.bin
   13  -rw-     4742144                      cmterm-7970_7971-sccp.7-0-1.tar
   14  -rw-     1006592                      cme-b-acd-2.1.0.0.tar
   15  -rw-        4308                      admin_user.html
   16  -rw-      642841                      admin_user.js
   18  -rw-         617                      CME_GUI_README.TXT
   20  -rw-       16344                      dom.js
   22  -rw-        6146                      ephone_admin.html
   24  -rw-        3724                      normal_user.html
   25  -rw-       77200                      normal_user.js
   29  -rw-        2393                      telephony_service.html
   31  -rw-        9968                      xml-test.html
   32  -rw-        3311                      xml.template
33292284 bytes total (3775816 bytes free)
BTW: I use sccp phone, CISCO IP Phone 7960.
Hello Chester,
Thanks for your support. I am now able to access the web based CISCO Call Manager Express page, and CISCO IPphone is not prompting "Configuring VLAN / Configuring IP address". So what i need to do next? what needs to be configure on the IP Phone and what are the configurations needed on the CME page?
Hope you can guide me through this. Tnx..
