CUCM 7.1.2 SQL script
m.ateeque
how do i create script to locate  dialed 800 & 911 number from all of my 6 sites, voice gateways configured in MGCP, all sites are meshed with MPLS [ PNT] wan, through blogs i have an idea  we can run a  sql command on pub or sub  to get desired results.
Appreciate your help..thanks
orobosa.orobor
  You can export CDR report in Seviceability to locate dialed numbers. Your file will be comma delimited file. I usually import the file into Excel and sort through to locate the numbers.
