E1 PRI outgoing call issue using QSIG
orbitbahrain
Hi.
I have a problem with ISDN QSIG.
My setup is:
A---PBX(Nortel PBX)------7206----Leasedline----7206----PBX(Nortel PBX)---B
I am facing problem in making outgoing calls from A end through the PRI (1/0) which is connected to Nortel PBX. but am able to receive the calls from other (B) end through the same PRI. incoming calls are coming with out any issue.
Note:- i have one more PRI (1/1) in the same router connected to same PBX which is working with out any problem. i am able to make outgoing and receive incoming call as well.
Any help is highly appreciated.
Please find attached my router config.
Thanks & Regards
orbitbahrain
Hi All,
Would you please check my query and help me to fix the problem
Thanks in advance
