FXO to Vonage ATA
mmitchell
I have temporary use of a callmanager at my home and I am trying to set up some test scenarios. I have a 1750 router with a vic-2fxo card connected to Vonage's Motorola ATA adapter. I have configured the dial peers and succesfully can receive a call but cannot send a call.
I have a buttset hooked onto my incoming phone cables so I can hear whats going on. WHen I try to send a call it goes off hook and I can hear dialtone, but it will not send digits.
WHen I do a show voice call it shows FXOGS_WAIT_DIAL_TONE. Is there any what to get this to work?
ghalman
Try using FXS port.
Or if you dont have FXS ports (in Cisco), then you need a convertor (e.g. from pcphoneline website. The product name is VoIP Gateway FXS to FXO Port Converter)
The connectivity example is:
Cisco FXO Port Vonage FXS Port.
It works perfectly!!!
:D
