how can i transfer a call from SIP 9971 to PBX system on CME router
CSCO11921999
hello everybody,
   I have a critical problem about interaction of transfering feature between CME router and pbx panasonic system in some status. let me explain more detail about this issue..i have a SIP 9971(CP-9971) registered on CME at the one site and a voice gateway that is connect with PBX system through a E1 pri trunk connection at the other site. totally the integration between CME and PBX is ok and there is no problem in two direction, i mean i can call pbx system from cp-9971 and vise versa but when i call from a phone  which is registered on PBX site to SIP 9971 which is registered on cisco CME call is connected,then when i try to transfer that call to another phone at PBX site, the session is open between two panasonic phones but no audio transmited in two direction. in addition every thing works fine about SCCP phones(transfer feature works fine). here is my configuration file. i hope someone could help me because i've searched a lot but no result help help help plz....
cme router 3845 configuration
VOIP-3845#show running-config
Building configuration...
Current configuration : 12657 bytes
! Last configuration change at 11:44:01 UTC Mon Oct 31 2011 by admin
! NVRAM config last updated at 11:44:02 UTC Mon Oct 31 2011 by admin
version 15.1
hostname VOIP-3845
boot-start-marker
boot-end-marker
no aaa new-model
clock calendar-valid
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  bind control source-interface Loopback10
  bind media source-interface Loopback10
  registrar server
voice register global
mode cme
source-address 192.168.2.1 port 5060
max-dn 720
max-pool 262
load 9971 sip9971.9-1-1SR1.loads
authenticate register
authenticate realm cisco.com
tftp-path flash:
file text
create profile sync 0063544528862458
camera
video
voice register dn  1
number 500
voice register dn  2
number 600
voice register dn  3
number 700
name test
voice register template  1
softkeys idle  Newcall Redial Cfwdall
softkeys connected  Confrn Endcall Hold Trnsfer
voice register pool  1
id mac B8BE.BF23.5242
type 9971
number 1 dn 1
template 1
username test password test
camera
video
blf-speed-dial 4 600 label "test"
voice register pool  2
id mac B8BE.BF9C.5476
type 9971
number 1 dn 2
template 1
username bank password bank
camera
video
voice register pool  3
id mac B8BE.BF9C.51D4
type 9971
number 1 dn 3
template 1
username test1 password test1
camera
video
voice register pool  4
id mac B8BE.BF9C.4FA2
number 1 dn 1
camera
video
crypto pki trustpoint TP-self-signed-1576175886
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1576175886
revocation-check none
rsakeypair TP-self-signed-1576175886
crypto pki certificate chain TP-self-signed-1576175886
certificate self-signed 01
  30820241 308201AA A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31353736 31373538 3836301E 170D3131 31303038 30393034
  34365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 35373631
  37353838 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D6EC 47BCDC3C 82F43FF3 23522678 2616868D 9910DCD2 E36016B3 D7B40DA7
  53A6E339 4978D451 21F051BE B21F8AD5 86B952DC 1ECCE371 3E094B54 26A41E14
  A3055C06 AE860756 425E5C50 E62B3287 631B1E87 9BAC2E39 2810E120 DA3BF823
  947EA591 81CA5489 1B868239 E835EC7C 0AA7651A 22D6E47F 545EBEF3 A172C9A3
  5A0D0203 010001A3 69306730 0F060355 1D130101 FF040530 030101FF 30140603
  551D1104 0D300B82 09564F49 502D3338 3435301F 0603551D 23041830 1680146C
  934AD072 99DDC600 ECD6F389 8F71E0C2 18EC2E30 1D060355 1D0E0416 04146C93
  4AD07299 DDC600EC D6F3898F 71E0C218 EC2E300D 06092A86 4886F70D 01010405
  00038181 000E82F6 5FBB847C 49226955 6F7DECE7 0B093513 D57C35D5 4CD22FA7
  8144A080 B0D56C8D 86AF8156 0152443A A3FBE59F B1AEFFBC BEB43E09 35757BAD
  4C06FC4A 0F3695E0 B00FBD30 4E8F36CE 7748F39C F9602650 7A1D2D48 DBC31237
  AE3D63CE 593D31F5 62E4916F D20E30E8 30DC55C0 120FBD26 D2768DBC A67DDC34
  5BDB66B1 E3
        quit
license udi pid CISCO3845-MB sn FOC14421Q1Y
archive
log config
  hidekeys
username admin privilege 15 secret 5 $1$Zf7j$P93opukmmEBIioVpjmHB3.
redundancy
ip address 192.168.2.1 255.255.255.0
interface Tunnel1
ip address 172.25.10.1 255.255.255.0
no ip redirects
ip nhrp map multicast dynamic
ip nhrp network-id 10
tunnel source GigabitEthernet0/1.1
tunnel mode gre multipoint
tunnel key 100
interface Tunnel2
ip address 172.25.11.1 255.255.255.0
no ip redirects
ip nhrp network-id 20
tunnel source GigabitEthernet0/1.2
interface Tunnel14
ip address 192.168.13.129 255.255.255.252
tunnel destination 10.2.68.25
interface Tunnel18
ip address 192.168.13.137 255.255.255.252
tunnel destination 10.9.160.236
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.1
encapsulation dot1Q 10
ip address 10.9.160.25 255.255.255.0
interface GigabitEthernet0/1.2
encapsulation dot1Q 50
ip address 10.10.9.25 255.255.255.0
router eigrp 202
network 172.25.11.0 0.0.0.255
network 192.168.2.0 0.0.0.15
redistribute static route-map MYMAP1
router eigrp 201
network 172.25.10.0 0.0.0.255
ip forward-protocol nd
ip http server
ip http secure-server
ip http path flash:/gui
ip route 10.2.68.0 255.255.255.0 10.9.160.1
ip route 10.10.0.0 255.255.0.0 10.10.9.1
ip route 10.64.164.30 255.255.255.255 10.9.160.1
ip route 192.168.14.0 255.255.255.0 192.168.13.130
ip route 192.168.17.0 255.255.255.0 Tunnel18
ip access-list standard REDIS1
permit 192.168.14.0
permit 192.168.17.0
route-map MYMAP1 permit 10
match ip address REDIS1
snmp-server community test RO
tftp-server flash:term11.default.loads
tftp-server flash:dkern9971.100609R2-9-0-3.sebn
tftp-server flash:kern9971.9-0-3.sebn
tftp-server flash:rootfs9971.9-0-3.sebn
tftp-server flash:sboot9971.111909R1-9-0-3.sebn
tftp-server flash:sip9971.9-0-3.loads
tftp-server flash:skern9971.022809R2-9-0-3.sebn
tftp-server flash:sccp11.9-0-2sr1s
tftp-server flash:SCCP11.9-1-1SR1S.loads
tftp-server flash:apps11.9-1-1TH1-16.sbn
tftp-server flash:cnu11.9-1-1TH1-16.sbn
tftp-server flash:cvm11sccp.9-1-1TH1-16.sbn
tftp-server flash:dsp11.9-1-1TH1-16.sbn
tftp-server flash:jar11sccp.9-1-1TH1-16.sbn
tftp-server flash:term06.default.loads
tftp-server flash:sip9971.9-1-1SR1.loads
tftp-server system:cme/sipphone
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:Desktops/320x212x12/CiscoLogo.png
tftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:gui/admin_user.html
tftp-server flash:gui/admin_user.js
tftp-server flash:gui/CiscoLogo.gif
tftp-server flash:gui/Delete.gif
tftp-server flash:gui/dom.js
tftp-server flash:gui/downarrow.gif
tftp-server flash:gui/ephone_admin.html
tftp-server flash:gui/logohome.gif
tftp-server flash:gui/normal_user.html
tftp-server flash:gui/normal_user.js
tftp-server flash:gui/Plus.gif
tftp-server flash:gui/sxiconad.gif
tftp-server flash:gui/Tab.gif
tftp-server flash:gui/telephony_service.html
tftp-server flash:gui/uparrow.gif
tftp-server flash:gui/xml-test.html
tftp-server flash:gui/xml.template
tftp-server flash:ringtones/Analog1.raw
tftp-server flash:ringtones/Analog2.raw
tftp-server flash:ringtones/AreYouThere.raw
tftp-server flash:ringtones/AreYouThereF.raw
tftp-server flash:ringtones/Bass.raw
tftp-server flash:ringtones/CallBack.raw
tftp-server flash:ringtones/Chime.raw
tftp-server flash:ringtones/Classic1.raw
tftp-server flash:ringtones/Classic2.raw
tftp-server flash:ringtones/ClockShop.raw
tftp-server flash:ringtones/DistinctiveRingList.xml
tftp-server flash:ringtones/Drums1.raw
tftp-server flash:ringtones/Drums2.raw
tftp-server flash:ringtones/FilmScore.raw
tftp-server flash:ringtones/HarpSynth.raw
tftp-server flash:ringtones/Jamaica.raw
tftp-server flash:ringtones/KotoEffect.raw
tftp-server flash:ringtones/MusicBox.raw
tftp-server flash:ringtones/Piano1.raw
tftp-server flash:ringtones/Piano2.raw
tftp-server flash:ringtones/Pop.raw
tftp-server flash:ringtones/Pulse1.raw
tftp-server flash:ringtones/Ring1.raw
tftp-server flash:ringtones/Ring2.raw
tftp-server flash:ringtones/Ring3.raw
tftp-server flash:ringtones/Ring4.raw
tftp-server flash:ringtones/Ring5.raw
tftp-server flash:ringtones/Ring6.raw
tftp-server flash:ringtones/Ring7.raw
tftp-server flash:ringtones/RingList.xml
tftp-server flash:ringtones/Sax1.raw
tftp-server flash:ringtones/Sax2.raw
tftp-server flash:ringtones/Vibe.raw
tftp-server flash:APPS-1.2.1.SBN
tftp-server flash:SYS-1.2.1.SBN
tftp-server flash:GUI-1.2.1.SBN
tftp-server flash:CP7921G-1.2.1.LOADS
tftp-server flash:TNUX-1.2.1.SBN
tftp-server flash:TNUXR-1.2.1.SBN
tftp-server flash:WLAN-1.2.1.SBN
tftp-server flash:apps37sccp.1-2-1-0.bin
tftp-server flash:APPSH-1.3.1.SBN
tftp-server flash:GUIH-1.3.1.SBN
tftp-server flash:CP7925G-1.3.1.LOADS
tftp-server flash:SYSH-1.3.1.SBN
tftp-server flash:TNUXH-1.3.1.SBN
tftp-server flash:WLANH-1.3.1.SBN
tftp-server flash:SCCP11.9-2-1S.loads
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:skern9971.022809R2-9-2-1.sebn
tftp-server flash:sip9971.9-2-1.loads
tftp-server flash:sboot9971.031610R1-9-2-1.sebn
tftp-server flash:rootfs9971.9-2-1.sebn
tftp-server flash:dkern9971.100609R2-9-2-1.sebn
tftp-server flash:kern9971.9-2-1.sebn
tftp-server flash:United_States/g4-tones.xml
tftp-server flash:English_United_States/gd-sip.jar
tftp-server flash:sboot9971.031610R1-9-1-1SR1.sebn alias sboot9971.031610R1-9-1-1SR1.sebn
tftp-server flash:rootfs9971.9-1-1SR1.sebn alias rootfs9971.9-1-1SR1.sebn
tftp-server flash:kern9971.9-1-1SR1.sebn alias kern9971.9-1-1SR1.sebn
tftp-server flash:dkern9971.100609R2-9-1-1SR1.sebn alias dkern9971.100609R2-9-1-1SR1.sebn
tftp-server flash:skern9971.022809R2-9-1-1SR1.sebn alias skern9971.022809R2-9-1-1SR1.sebn
control-plane
mgcp profile default
dial-peer voice 1 voip
description connection-trough-PBX
destination-pattern 0....
session target ipv4:192.168.13.130
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 100 voip
description K
destination-pattern 9T
no vad
dial-peer voice 5 voip
shutdown
destination-pattern *3709
session protocol sipv2
session transport tcp
codec g711ulaw
no vad
dial-peer voice 2 pots
incoming called-number .
dial-peer voice 10 voip
gatekeeper
shutdown
telephony-service
em logout 0:0 0:0 0:0
max-ephones 262
max-dn 400
ip source-address 192.168.2.1 port 2000
load 7911 SCCP11.9-2-1S
max-conferences 12 gain -6
web admin system name admin secret 5 $1$IKnn$tyKyuBcGqXFl6nhxCSu.z0
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Oct 29 2011 12:39:25
ephone-template  1
softkeys connected  Confrn Endcall Trnsfer Hold
keep-conference endcall
ephone-dn  1  dual-line
number 200
label test
name test
ephone-dn  2  dual-line
number 300
label Sepahbod
name Sepahbod
ephone-dn  4  dual-line
number 666
ephone-dn  5  dual-line
number 660
ephone-dn  6  dual-line
number 670
ephone-dn  7  dual-line
number 770
ephone-dn  8  dual-line
number 770
ephone-dn  9  dual-line
number 999
ephone  1
device-security-mode none
mac-address 18EF.639F.BCB0
button  1:1
ephone  2
mac-address 0025.8418.B017
ephone-template 1
button  1:2
ephone  3
mac-address F04D.A243.3154
button  1:4
ephone  4
mac-address 6CF0.496A.69E9
button  1:4
ephone  5
mac-address 0015.E987.345F
button  1:5
ephone  6
mac-address 0024.1DEA.614A
button  1:6
ephone  9
mac-address 001D.7D4D.4DCB
button  1:9
line con 0
line aux 0
line vty 0 4
login local
transport input telnet
scheduler allocate 20000 1000
end
and Voice Gateway connected two PBX system configuration
Current configuration : 3486 bytes
version 15.1
hostname Voice-GW
boot-start-marker
boot-end-marker
card type e1 0 2
no aaa new-model
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
no ipv6 cef
isdn switch-type primary-net5
voice service voip
h323
voice-card 0
license udi pid CISCO2811 sn FHK1352F0E9
username admin privilege 15 secret 5 $1$O6AN$1kvvqiLdIl3/ZTHoyYRy0/
redundancy
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/2/1
interface Tunnel14
ip address 192.168.13.130 255.255.255.252
tunnel source FastEthernet0/1
tunnel destination 10.9.160.25
interface Tunnel17
ip address 192.168.13.134 255.255.255.252
interface FastEthernet0/0
ip address 192.168.14.252 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.2.68.25 255.255.255.0
duplex auto
speed auto
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn incoming-voice voice
no cdp enable
router eigrp 201
network 192.168.14.0
no ip http server
no ip http secure-server
ip route 10.9.160.0 255.255.255.0 10.2.68.1
ip route 10.128.0.69 255.255.255.255 Tunnel14
ip route 192.168.2.1 255.255.255.255 192.168.13.129
ip route 192.168.17.0 255.255.255.0 Tunnel14
tftp-server flash:jar11sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp11.9-2-1TH1-13.sbn
tftp-server flash:cvm11sccp.9-2-1TH1-13.sbn
tftp-server flash:cnu11.9-2-1TH1-13.sbn
tftp-server flash:apps11.9-2-1TH1-13.sbn
control-plane
voice-port 0/0/0
caller-id enable
voice-port 0/0/1
voice-port 0/0/2
supervisory disconnect dualtone mid-call
dial-type pulse
disc_pi_off
output attenuation 1
echo-cancel coverage 32
timeouts call-disconnect 5
timeouts wait-release 1
timing hookflash-out 50
timing sup-disconnect 50
connection plar 600
caller-id enable
voice-port 0/0/3
caller-id enable
voice-port 0/2/0:15
dial-peer voice 1 pots
description connection-to-PBX
direct-inward-dial
port 0/2/0:15
forward-digits 4
destination-pattern ...
session target ipv4:192.168.13.129
no vad
dial-peer voice 20 pots
description FXO-K
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/0/2
prefix 9
dial-peer voice 30 pots
description FXO-K2
direct-inward-dial
port 0/0/1
prefix 9
telephony-service
max-ephones 20
max-dn 100
ip source-address 192.168.14.252 port 2000
cnf-file location flash:
load 7911 term11.default.loads
max-conferences 8 gain -6
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
number 770
line con 0
line aux 0
line 1/0 1/15
line vty 0 4
login local
end
ADAM CRISP
Level 4
Level 4
Having looked at your spreadsheet I see you're failing H323 transfers back to your ISDN system, but only under certain circumstances. Quite why, I'm not sure, possibly because you haven't codec defined on your H323 dial peers. or it could be something else
I think you may be able to work around the problem by adding
" supplementary-service h450.12 " under voice service voip on your CME router as a quick fix.
reference
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrans.html#wpxref44614
worth a try
Adam
