How to configure QoS in 2950 switch
stella.florence
I've to configure QoS in a 2950 switch with Cisco IOS 12.1(22)EA4. But the IOS does not support class-map and policy-map command. But according to the cisco documentation it has to support QoS . Can you guide me in this?
Thanks and Regards,
Stella Florence W.
mheusinger
Level 10
Level 10
the 2950 is supporting QoS, but is limited with respect to its capabilities. The complete picture is f.e. given in the chapter "Configuring QoS" in "Catalyst 2950 and Catalyst 2955 Switch Software Configuration Guide, 12.1(22)EA2"
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00802c31e8.html
This should pretty much answer all your questions. Another good resource to tackle QoS is the "Enterprise QoS Solution Reference Network Design Guide Version 3.3"
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
Hope this helps! Please use the rating system.
Regards, Martin
