Output from debug dialpeer...the incoming digits (according to my telco are 7116...callerid is not supported on the t1 trunks coming in...
*Mar 3 05:18:55.794: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x84164434,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_PORT;
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=100
*Mar 3 05:18:55.794: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@5831
