11-07-2008 02:48 AM
I have a 7206VXR with NPE400. I have one T1 connected to 4/0 and a quintum D3000 connected to 4/3, the quintum should received the call and route it to RADIUS Server. All these circuit are up and sync. The problem is when I tried to make a call, it gets busy "Ciruit/Channel not available". And it does event reached the D3000, I don't see any logs on it, that shows a call coming from the VXR. Below is my dial peer and I will post the debug messages on the next post. Am I missing something on the configuration in the VXR side ? Hope you could help me find a resolution to this problem.
controller T1 4/0
framing esf
service-type ccs-voice
linecode b8zs
cablelength long 0db
pri-group timeslots 1-24
description connected to PSTN_Provider
controller T1 4/2
framing esf
linecode b8zs
description cross.connect_d3000
interface Serial4/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
interface Serial4/2:23
no ip address
encapsulation hdlc
no cdp enable
voice-port 4/0:23
input gain 6
echo-cancel coverage 32
bearer-cap Speech
voice-port 4/2:23
input gain 6
bearer-cap Speech
dial-peer voice 108 pots
description [ connected to PSTN_Provider ]
incoming called-number .T
direct-inward-dial
port 4/0:23
dial-peer voice 2007 pots
destination-pattern 2014021661
port 4/2:23
forward-digits 10
11-07-2008 02:49 AM
Follow up: Debug Messages
Debug Messages: sh isdn all
Nov 7 10:34:31.283: ISDN Se4/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=11 nr=11
Nov 7 10:34:31.283: ISDN Se4/0:23 Q931: SETUP pd = 8 callref = 0x04F5
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64kbit/s
Channel ID i = 0xA98387
Exclusive, Channel 7
Calling Party Number i = 0x1183, '9148461321199'
Plan:ISDN, Type:International
Called Party Number i 0xA1, '2014021661'
Plan:ISDN, Type:National
Nov 7 10:34:31.283: ISDN Se4/0:23 Q921d: process_rxdata: Frame sent to L2
Nov 7 10:34:31.283: ISDN Se4/0:23 PACKET: L2IF_SendPkt:
source_id (0x200), state (0x0),
dest_id (0x20A), event (0x141),
sapi (0x0), ces (0x0), call_id (0x0),
chan_id (0x0), int_id (0x6678C834), free_pkt (0x1),
pkt (0x65115DF4), msecs (0x0), priority (0xA)
Nov 7 10:34:31.287: ISDN Se4/0:23 PACKET: L2IF_DispPak: packet - start(E23DED8), size (49)
Nov 7 10:34:31.287: 02011616080204F50504038090A21803
Nov 7 10:34:31.287: A983876C0F1183393134383436313332
Nov 7 10:34:31.287: 31313939700BA1323031343032313636
Nov 7 10:34:31.287: ISDN Se4/0:23 PACKET: L2IF_SendPkt: Sending from L2
dest_id = 0, source_id = 512, prim = 141
priv_ln = 4, int_id = 1719191604
datastart = E23DEC8, netstart = E23DED8, datasize = 65
Nov 7 10:34:31.287: ISDN Se4/0:23 PACKET: L2IF_DispPak: packet - start(E23DEC8), size (65)
Nov 7 10:34:31.287: 6678C83400000200014104950000016D
Nov 7 10:34:42.507: ISDN Se4/0:23 Q921: User TX -> INFO sapi=0 tei=0, ns=17 nr=18
Nov 7 10:34:42.507: ISDN Se4/0:23 Q931: RELEASE_COMP pd = 8 callref = 0x84FB
Cause i = 0x80AC - Requested circuit/channel not available
Nov 7 10:34:38.067: ISDN Se4/2:23 Q921f: User RX <-
Nov 7 10:34:38.067: 02010101
Nov 7 10:34:38.067: ISDN Se4/2:23 Q921: User RX <- RRp sapi=0 tei=0 nr=0
Nov 7 10:34:38.067: ISDN Se4/2:23 Q921d: process_rxdata: Frame sent to L2
Nov 7 10:34:38.067: ISDN Se4/2:23 PACKET: L2IF_SendPkt:
chan_id (0x0), int_id (0x668B71F4), free_pkt (0x1),
pkt (0x646422E4), msecs (0x0), priority (0xA)
Nov 7 10:34:38.067: ISDN Se4/2:23 PACKET: L2IF_DispPak: packet - start(E001ED8), size (4)
11-07-2008 02:59 AM
Heres another debug messages:
Nov 7 10:54:44.644: ISDN Se4/0:23 Q931: RX <- SETUP pd = 8 callref = 0x051D
Standard = CCITT
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Called Party Number i = 0xA1, '2014021661'
Nov 7 10:54:44.644: ISDN Se4/0:23 EVENT: process_rxstate: ces/callid 1/0x5C7 calltype 2 CALL_INCOMING
Nov 7 10:54:44.644: ISDN Se4/0:23 EVENTd: isdn_get_guid: Got Guid 52410CAE856C
Nov 7 10:54:44.644: ISDN Se4/0:23 EVENT: call_incoming: call_id 0x05C7, Guid = 52410CAE856C
Nov 7 10:54:44.644: ISDN Se4/0:23 EVENTd: calltrkr_incoming_call: call_id=0x5C7
Nov 7 10:54:44.644: ISDN Se4/0:23 EVENTd: calltrkr_setup_received: isdn_info=1719204500l, call_id=0x5C7 ANSWER
Nov 7 10:54:44.644: ISDN Se4/0:23 EVENTd: calltrkr_setup_received: calltracker disabled
Nov 7 10:54:44.644: ISDN Se4/0:23 EVENTd: calltrkr_setup_received: isdn_info=1718950392l, call_id=0x5C7 ANSWER
Nov 7 10:54:44.644: ISDN Se4/0:23 EVENTd: call_incoming: b channel 0, call type is VOICE ULAW
Nov 7 10:54:44.644: ISDN Se4/0:23 EVENTd: call_incoming: Received a VOICE call from 9148461321199 on b channel 0 at 64 Kb/s
Nov 7 10:54:44.644: ISDN Se4/0:23 EVENTd: sys_cons[12].clng_name=0
Nov 7 10:54:44.648: ISDN Se4/0:23 EVENTd: call_incoming: Sending event to RM. Callid 1479
Nov 7 10:54:44.648: ISDN Se4/0:23 EVENTd: call_incoming: RM returned
Nov 7 10:54:44.648: ISDN CDAPI: cdapi_find_tsm found a GTD message IAM,
PRN,isdn*,,NI***,
USI,rate,c,s,c,1
USI,lay1,ulaw
TMR,00
CPN,04,,1,2014021661
CGN,06,,1,y,4,9148461321199
CPC,09
FCI,,,,,,,y,
GCI,52410caeabf111dd856c00b04aaa2800
end of gtd length is 179
Nov 7 10:54:44.648: ISDN Se4/0:23 EVENTd: process_disconnect: call id 0x5C7, call type is VOICE, b_idb 0x6674F384, ces 1, cause Unknown cause value(0xAC)
Nov 7 10:54:44.652: ISDN Se4/0:23 EVENTd: calltrkr_call_disconnected: isdn_info=0x667519F8, call_id=0x5C7
Nov 7 10:54:44.652: ISDN Se4/0:23 EVENTd: process_disconnect: Raw Release Message
Nov 7 10:54:44.652: 4B0C0105C7040802FFAC080380AC81
Nov 7 10:54:44.652: ISDN Se4/0:23 CDAPI: cdapi_mib_update msg CALL_DISC, remote number 9148461321199, connected? No
Nov 7 10:54:44.652: ISDN EVENTd: cc_clear_free_list freeing 0x66F00860
Nov 7 10:54:44.652: ISDN Se4/0:23 EVENT: process_rxstate: ces/callid 1/0x5C7 calltype 2 CALL_CLEARED
Nov 7 10:54:44.652: ISDN Se4/0:23 EVENTd: calltrkr_call_cleared: isdn_info=0x6678FA94, call_id=0x5C7
Nov 7 10:54:44.652: ISDN Se4/0:23 EVENTd: calltrkr_call_cleared: isdn_info=0x667519F8, call_id=0x5C7
Nov 7 10:54:44.652: ISDN CDAPI: cdapi_find_tsm found a GTD message RLC,
PRN,isdn*,,NI***,
end of gtd length is 27
