PRI Signalling on E1 Leased Line
susanto_leman
I am having a problem rite now. I have E1 Leased Line. One is connected to ISDN switch and the other end is connected AS5300. I have configured the E1 to use the PRI signalling and it looks fine.
Network Diagram
VOIP Nets----ISDN Switch
| E1/Leased Line
| Back2Back
AS5300-------------SIP Svr
| Voice over IP |
My problem is whenever I route the calls from sip server to AS5300 by using over IP the sip phone can not make call. But there is no problem when I route the call from SIP server to AS5300 by using back to back connection.
Here are the configs and debugs
Thanks alot
voice-port 0:D
!back to back
cptone SG
voice-port 3:D
! PRI overleased Line
cptone SG
dial-peer voice 1000 voip
! connect to gatekeeper
huntstop
preference 3
destination-pattern .T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
voice-class codec 1
voice-class h323 1
session target ras
tech-prefix 25940#
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
fax rate 9600
icpif 50
dial-peer voice 200 pots
!PRI over LeasedLine
huntstop
preference 10
no digit-strip
port 3:D
dial-peer voice 400 pots
huntstop
destination-pattern 006T
port 3:D
dial-peer voice 300 pots
incoming called-number T
direct-inward-dial
port 3:D
dial-peer voice 100 pots
direct-inward-dial
port 0:D
debug isdn event de
Aug 21 10:51:15.444 SGT: ISDN Se3:15 EVENTd: process_pri_call: call id 0x8036, number 65XXXXXXX, speed 0, call type VOICE, redial No, CSM call No, pdata Yes
Aug 21 10:51:15.444 SGT: ISDN Se3:15 EVENTd: pak_private_number: Calling Number IE is being stripped
Aug 21 10:51:15.444 SGT: ISDN Se3:15 EVENTd: pak_private_number: called type/plan overridden by call_decode
Aug 21 10:51:15.444 SGT: ISDN Se3:15 EVENTd: pak_public_number: Calling Number IE is being stripped
Aug 21 10:51:15.448 SGT: ISDN Se3:15 EVENTd: calltrkr_setup_received: isdn_info=1663202540l, call_id=0x8036 ORIGINATE
Aug 21 10:51:15.448 SGT: ISDN Se3:15 EVENTd: calltrkr_setup_received: calltracker disabled
Aug 21 10:51:15.472 SGT: ISDN Se3:15 EVENTd: calltrkr_setup_received: isdn_info=1663740460l, call_id=0x8036 ORIGINATE
Aug 21 10:51:18.605 SGT: ISDN Se3:15 EVENTd: process_rxstate: cause=0x1 (1), cause_present=1
Aug 21 10:51:18.605 SGT: ISDN Se3:15 EVENTd: calltrkr_call_disconnected: isdn_info=0x632274EC, call_id=0x8036
Aug 21 10:51:18.605 SGT: ISDN Se3:15 EVENTd: calltrkr_call_disconnected: isdn_info=0x632AAA2C, call_id=0x8036
Aug 21 10:51:18.605 SGT: ISDN Se3:15 EVENTd: process_disc_ack: call id 0x8036, ces 1, call type VOICE cause 0x1
Aug 21 10:51:18.621 SGT: ISDN EVENTd: cc_clear_free_list freed 0x637178E4
Aug 21 10:51:18.621 SGT: ISDN Se3:15 EVENTd: calltrkr_call_cleared: isdn_info=0x632274EC, call_id=0x8036
Aug 21 10:51:18.621 SGT: ISDN Se3:15 EVENTd: calltrkr_call_cleared: isdn_info=0x632AAA2C, call_id=0x8036
susanto_leman
the diagram doesnt look good...I attached the diagram in txt file.
thanks
susanto_leman
and configuration correction....
huntstop
preference 2
no digit-strip
port 3:D
susanto_leman
solved....carrier issue..
thanks
