Problems with MGCP
ABM Networking
Im having some issues getting MGCP to register on our CCM (Version 8.6.2.21900-5) with an 800 series router (Specifically a C888SRST-W) if i bind the BRI interface to the CCM, Layer 2 will not activate. If I remove the binding command then the link activates as expected however I need this bound to the CUCM manager.
On the 888 router, the BRI port is known as BRI4 rather than the expected 0/0/0 format. On the CUCM the only options are 0/0/0 etc. Could this be the source of my problems? We have many 1800/2800/3800 series routers with BRI modules where this config works fine.
Craig
Carl Messer
If you add a pots dial peer with service mgcpapp and the port number it will work.
Carl Messer
