QOS for VOIP 1720 Router by port
roger200x
Hi, I need to set QOS for UDP ports 5004 and 5440-5445. I would like to just do it by the port number and avoid lists, ip addresses, macs and all that. Is there a way to do this?
Roger
jkim
You can turn on NBAR, if your IOS supports it and see if it picks up the application. If not, you'll need to use acl to pick out the ports.
John
