QoS with Loopback interface
e.deangelis
i have configure vpn tunnel on my loopback interface and when i insert service-policy output command i receive " Class Based Weighted Fair Queueing not supported on interface Loopback0".
How to apply QoS in loopback interface?
I f apply policy in ATM 0.1 interface it's the same?
8 Replies 8
pkhatri
Level 11
Level 11
You have to apply a 'parent' shaping policy on the interface in order to apply QoS to it.
Try something like the following:
policy-map Parent
class class-default
shape average 256000
service-policy Child
policy-map Child
class class1
bandwidth 64
class class2
bandwidth 32
interface loopback10
service-policy output Parent
Hope that helps - pls rate the post if it does.
Paresh
Hi, this is my policy:
class-map match-all telnet
match access-group 130
class-map match-all voice
match access-group 120
policy-map VOICE-POLICY
class voice
priority percent 70
set dscp ef
class telnet
policy-map LOOPBACK
class class-default
service-policy VOICE-POLICY
inteface loopback 0
service-policy out LOOPBACK
It's correct?
If i do a "sh run" command in loopback interface not see nothing.
Actually, what I earlier suggested will not work on loopback interfaces, since you can't shape on them. In fact, it does not make much sense to apply QoS policies to loopback interfaces at all.
There should be an alternative location to apply the policy in your case. Would you be able to post your config ?
Paresh
This my config:
PnP Address provider:12.x.x.x
Pubblic IP Address:11.x.x.x
Local LAN: 192.168.8.x
___________________________________________
version 12.3
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable password xxxx
username xxxx privilege 15 password xxx
aaa new-model
aaa authentication login console enable
aaa authentication login telnet local
aaa authentication ppp default none
aaa authorization exec console none
aaa authorization exec telnet local
aaa session-id common
ip subnet-zero
ip multicast-routing
ip audit po max-events 100
no ftp-server write-enable
crypto isakmp policy 11
hash md5
authentication pre-share
crypto isakmp key 6 psk address VPN-ADDRESS
crypto ipsec transform-set ROM esp-des esp-md5-hmac
crypto map nolan 11 ipsec-isakmp
set peer xx.xx.xx.xx
set transform-set ROM
match address 120
interface Loopback0
ip address 11.11.x.x.x.255.248
ip nat outside
crypto map nolan
interface Ethernet0
ip address 192.168.8.1 255.255.255.0
ip nat inside
no ip mroute-cache
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address 12.12.x.x.x.x.252
ip nat outside
pvc 8/35
encapsulation aal5snap
ip classless
ip route 0.0.0.0 0.0.0.0 12.12.12.225
ip route 192.168.17.0 255.255.255.0 Loopback0
ip route 192.168.149.0 255.255.255.0 Loopback0
ip route 192.168.150.0 255.255.255.0 Loopback0
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Loopback0 overload
access-list 101 deny ip any 192.168.149.0 0.0.0.255
access-list 101 deny ip any 192.168.150.0 0.0.0.255
access-list 101 deny ip any 192.168.17.0 0.0.0.255
access-list 101 permit ip 192.168.8.0 0.0.0.255 any
access-list 120 permit ip 192.168.8.0 0.0.0.255 192.168.149.0 0.0.0.255
access-list 120 permit ip 192.168.8.0 0.0.0.255 192.168.150.0 0.0.0.255
access-list 120 permit ip 192.168.8.0 0.0.0.255 192.168.17.0 0.0.0.255
control-plane
line con 0
login authentication console
no modem enable
transport preferred all
transport output all
stopbits 1
line aux 0
line vty 0 4
exec-timeout 30 0
password xxxxx
login authentication telnet
length 0
transport input all
scheduler max-task-time 5000
end
______________________________________________
Thanks for your HELP
You could try the following additional config:
policy-map MyPolicy
class class1
bandwidth 64
class class2
bandwidth 32
qos pre-classify
interface ATM0.1
pvc 8/35
service-policy output MyPolicy
Paresh
A much easier solution would be to upgrade to the latest 12.4M (mainline) release and simply use a encrypted tunnel interface. you would be applying the QoS policy to the tunnel interface which would have a source of 'interface tunnel0'. Some advantages:
1) This way you are only shaping traffic that uses the tunnel and not all ATM traffic.
2) You would use your routing table to direct traffic to the tunnel rather than the crypto map BS.
3) You won't be creating an IPSec SPI for each and every subnet to subnet/host traffic direction, the protected tunnel negotiates a 0.0.0.0/0 single SPI in each direction for the life of the IPSec tunnel.
4) You can run multicast (and, therefore OSPF or EIGRP routing protocol), if desired, without having to mess with a GRE tunnel AND the afformentioned crypto map BS.
5) The virtual tunnel interface uses dead peer detection, so you will know if the remote site goes down no differently than how a p-p T1 keepalive works. As more and more WANs are built using VPN technologies, this is important to maintain status on the remote sites. This is especially true as many service providers are offering layer 3 MPLS services which locally terminate traffic at both ends. If the remote DSL or circuit goes down, there would be no notification to the central site, for example.
See the following URLs for more information:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a008041faef.html
http://www.cisco.com/en/US/products/ps6635/products_white_paper0900aecd8029d629.shtml
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns656/c649/cdccont_0900aecd80402f0a.pdf
Please ask more questions if this is something you want to explore further, and rate this post if it helped you...
Hi thanks for your help.
I have used this methods:
ip access-list extended VOIP
permit udp 192.168.13.0 0.0.0.255 192.168.149.0 0.0.0.255 dscp ef
class-map match-all VOICE
match access-group name VOIP
policy-map qos_for_voip
class VOICE
priority 64
set ip dscp ef
policy-map QoSVPN
class class-default
service-policy qos_for_voip
interface Loopback0
service-policy output QoSVPN
BUT IF I SHOW RUNNING CONFIG i NOT SEE service-policy command in the loopback interface.
The show running-config command does not display policy map in loopback interface.
If i write "show policy-map interface loopback 0" there are not nothings.
I have a cisco 837...why?
I don't believe a service-policy can be configured on a loopback interface. Are you sure the router didn't complain when you attempted to apply this config? i.e. did you 'term mon' via your remote ssh session to the router to see the barf message(s)?
