Route pattern pre dot Vs Dial Issue
Hi !
I have issue with route pattern pre-dot digit.
I have configured route pattern with pre dot digit because as all of them new that
  Local call : 0 followed by number
  National : 00 followed by number
ISDN : 000 followed by number as per PSTN we have to use .T pattern and followed by country code,local code and national code to dial out our PSTN line.
You may be noticed that While receiving call you may be received only Number
If you want to re-dial . You have to go for edit and put 0 or 00 or 000 followed by number to dial out,
Is there any solution guys ?
We should dial with out dialing pre-dotted digit code.
Jayaraja R
0 Replies 0
