SIP source address control on a gateway
nwittenberg
Level 4
Level 4
Is there a way to control the SIP-UA source address for signaling and RTP on a gateway such as in h323 with the h323-gateway bind command? I want to do this with a loop back address so I can load balance over two Gigports.
teodorgeorgiev
Level 4
Level 4
In config mode enter these commands:
1. config service voip
2. sip
3. bind all loopback 0
with the keyword "all" you set this interface as a source for both the RTP (media) and call signalling.
If you want to set it as a source only for the signalling thread, use the keyword "control" instead of "all".
I think that is the correct set of commands.
Better double check in Cisco documentation.
teodorgeorgiev
Level 4
Level 4
2. sip
