trouble adding second port BRI in a 2801 MGCP gateway
proxitel
my config is CCM 413 with a 2801 SRST including a VIC2-2BRI .
I have configured the 2801 as MGCP gateway on the CCM, added the module VIC2-2BRI and configured the BRI 0/0/0 in this gateway.
this BRI work properly with the PSTN . I can make successfull call inbound and outbound
Now I want to add the second BRI (ie BRI 0/0/1 ) in the gateway for the same hunt group, the same PSTN provider.
When I do that this BRI can't register and make different kind of problem on the existing well working BRI.
for example I noticed that I can make inbound or outbound call with connected state but no voice in the two way.
I noticed also that the first BRI become completely blocked after two call.
I have verified the conf of the BRI 0/0/1 but i don't see any difference with the BRI 0/0/0 .
the only way to get back good working of the BRI 0/0/0 is to remove BRI 0/0/1 from the gateway conf.
KronosNOC
Hi there,
I think that I have also the same problem at our location in Germany!
The same situation is appeared to us.
Can we share our config please?
h2t
in fact i have activated a TAC request and get a new bin for my 2801 ²c2801-spservicesk9-mz.124-4.4.T.bin²
That is a good news though. Can you please share to me the TAC case nr? So I can refer this to tAC. Because we have also opened a CASE for the same problem on the 3725 but not hear from TAC yet for the patch!
I got another image ie. IPVOICE version 12.4.1.9 from a friend that has the patch for this problem on the 2801 but there is no SPSERVICES image yet.
Now it looks that Cisco has a newer image.
Thanks in advance.
hello,
my TAC service request number was 601940397
after that i found that my gateway don't arrive to play dtmf code to pstn and i got a new IOS for this .
not sure that we can have more than two BRI with this release.
good luck
regards
