VG200 Problem
midgar31
Hello;
I have GV200 connect to a Cat3524 a then a Cat6509 and connect to the 6509 a router with the T1 to a my PABX, when i try connect the VG200 directly to the 6509(making more short the path), the FE port in the VG200 dont come up, but in the 3524 all work fine with out intervention, both port have the same configuration (duplex, speed, vlan), any suggestion?
j-block
Level 4
Level 4
Looks like some hardware issue with the VG200 router.
