VoIP issue between Cisco 3725 Router and Cisco 2691 Router
mkirankumar
Hi !!!
Voice calls are happening from Cisco 2691 to Cisco 3725 router and when calling from 3725 router to 2691 router call goes blank or gets disconnected immediately or gives continuous busy tone. Kindly help in resolving this issue.
3725_HYD#show ver
IOS (tm) 3700 Software (C3725-IS-M), Version 12.3(13a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 26-Apr-05 01:44 by ssearch
Image text-base: 0x60008AF4, data-base: 0x61C36000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
ROM: 3700 Software (C3725-IS-M), Version 12.3(13a), RELEASE SOFTWARE (fc2)
3725_HYD uptime is 5 days, 11 hours, 37 minutes
System image file is "flash:c3725-is-mz.123-13a.bin"
cisco 3725 (R7000) processor (revision 0.1) with 120832K/10240K bytes of memory.
Processor board ID JPE081410L2
R7000 CPU at 240MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Basic Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
4 ISDN Basic Rate interface(s)
2 Voice E & M interface(s)
DRAM configuration is 64 bits wide with parity disabled.
55K bytes of non-volatile configuration memory.
31744K bytes of ATA System CompactFlash (Read/Write)
3725_HYD#
CISCO 3725 Router Config (E&M Card)
voice-port 2/0/0
operation 4-wire
type 5
signal immediate
cptone IN
timeouts initial 5
timing percentbreak 60
voice-port 2/0/1
operation 4-wire
type 5
signal immediate
cptone IN
timeouts initial 5
dial-peer voice 8 voip
destination-pattern 8...
session target ipv4:10.68.2.6
codec g729br8
dial-peer voice 4 pots
destination-pattern 4
port 2/0/0
dial-peer voice 5 pots
port 2/0/1
2691-BALLABHGARH#show ver
IOS (tm) 2600 Software (C2691-IS-M), Version 12.3(10d), RELEASE SOFTWARE (fc2)
Compiled Tue 03-May-05 04:37 by dchih
Image text-base: 0x60008AF4, data-base: 0x61BAE000
ROM: 2600 Software (C2691-IS-M), Version 12.3(10d), RELEASE SOFTWARE (fc2)
2691-BALLABHGARH uptime is 5 days, 17 hours, 25 minutes
System returned to ROM by reload
System image file is "flash:c2691-is-mz.123-10d.bin"
cisco 2691 (R7000) processor (revision 0.1) with 251904K/10240K bytes of memory.
Processor board ID JPE082810RP
R7000 CPU at 160MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
Bridging software.
2 ISDN Basic Rate interface(s)
31360K bytes of ATA System CompactFlash (Read/Write)
2691-BALLABHGARH#
voice-port 1/0/0
operation 4-wire
type 5
signal immediate
input gain -3
cptone IN
timeouts initial 5
voice-port 1/0/1
operation 4-wire
type 5
signal immediate
input gain -3
cptone IN
timeouts initial 5
dial-peer voice 4 voip
destination-pattern 4...
session target ipv4:10.195.50.134
codec g729br8
dial-peer voice 8 pots
port 1/0/0
dial-peer voice 9 pots
port 1/0/1
b.speltz
Level 4
Level 4
You can use debug voip ccapi inout.
try calls from router using csim # .
Also try out the document below
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094045.shtml
