VoIP issue with 881
iosolutions1
I have a strange issue with outgoing calles when connected to cisco 881.
I got an IPphone (cisco SPA502G) which is registered to our SipServer (Public IP Server). in the past we had the 871 unit and everything was OK.
since we replaced it with the new 881, I cannot make outgoing calles only incoming works.
the configuration is the same and very simple with no special NAT for the IP Phone:
interface FastEthernet4
description ### WAN ###
ip address X.X.X.X 255.255.255.248
ip nat outside
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 remark LAN NAT
access-list 1 permit 192.168.10.0 0.0.0.255
Is there something specific which is needed for the VoIP on the new 800 serias ?
Thanx,
   Arik
arwanadesign
Ancient post but just incase anyone else stumbles across this, you could try disabling SIP ALG on the 881 by including the following:
no ip nat service sip udp port 5060
(or whatever SIP port you are using)
cheers
