VOIP Problem ISDN PRI and Alcatel 4400
iganesh79
I am trying to Configuring VOIP between two sites using IDDN PRI E1 and Alcatel PBX 4400. A
Ciso 3640 router is being used as the VOIP gateway and it has the E1-PRI which connects to
the Alcatel PBX, I used the following cabling to connect the PBX and the E1-PRI -
Cisco PRI - Alcatel
RJ-45
Pin 1 <--> TX
Pin 2 <--> TX
Pin 4 <--> RX
Pin 5 <--> RX
I don't see any alarms either in the PRI or in the PRA2 Card of the PBX. Everything seems to be fine. But still the Layer2 is not getting established, If I enable debug q921 I see "Bad frame Received" messages,I tried changing the Voice card, But that didn't help. Please find the debug details below, Any help is appreciated.
Ganesh
*Mar 1 04:43:55.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:43:56.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:43:57.406: ISDN Se1/0:15: Event: received NL_REL_IND
*Mar 1 04:44:02.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:03.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:04.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:05.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:06.406: ISDN Se1/0:15: Event: received NL_REL_IND
*Mar 1 04:44:11.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:12.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:13.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:14.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:15.406: ISDN Se1/0:15: Event: received NL_REL_IND
*Mar 1 04:44:15.606: ISDN Se1/0:15: RX <- BAD FRAME(0x00017F)Line may be looped
*Mar 1 04:44:16.618: ISDN Se1/0:15: RX <- BAD FRAME(0x00017F)Line may be looped
*Mar 1 04:44:17.638: ISDN Se1/0:15: RX <- BAD FRAME(0x00017F)Line may be looped
*Mar 1 04:44:18.658: ISDN Se1/0:15: RX <- BAD FRAME(0x00017F)Line may be looped
*Mar 1 04:44:20.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:21.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:22.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:23.406: ISDN Se1/0:15: TX -> SABMEp c/r=0 sapi=0 tei=0
*Mar 1 04:44:24.406: ISDN Se1/0:15: Event: received NL_REL_IND
Router#show controllers e1 1/0
E1 1/0 is up.
Applique type is Channelized E1 - balanced
Description: QSIG connection to PBX
Far End Block Errors Detected
Receiver has loss of signal.
alarm-trigger is not set
Version info Firmware: 20011015, FPGA: 11
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (147 seconds elapsed):
79170 Line Code Violations, 47468 Path Code Violations
88 Slip Secs, 0 Fr Loss Secs, 147 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 147 Unavail Secs
Router#
Router#sh isdn status
Global ISDN Switchtype = primary-qsig
ISDN Serial1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-qsig
**** Slave side configuration ****
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x7FFF7FFF
Number of L2 Discards = 0, L2 Session ID = 9
Total Allocated ISDN CCBs = 0
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
Number of L2 Discards = 0, L2 Session ID = 10
Router#
5 Replies 5
feberle
Check if ur PBX is using CRC4 or not and if it's acting as USER or NETWORK Side. Check also the ISDN switch-type.
Post ur conf with the E1 conf and serial conf.
Rdgs
Hi Feberle!
Thanks for your response, I confirmed that Alcatel is acting as Master and the Router is slave, Framing is CRC4 at the PBX and Router end. ISDN Switch type is QSIG at both ends, below is the config, Awaiting for your reply.
Ganesh
Building configuration...
voice-card 1
isdn switch-type primary-qsig
isdn voice-call-failure 0
call rsvp-sync
controller E1 1/0
pri-group timeslots 1-31
description QSIG connection to PBX
translation-rule 1
Rule 0 ^7... 47
Rule 1 ^2... 22
Rule 2 ^5... 55
Rule 3 ^4... 14
interface Loopback1
ip address 192.168.x.x 255.255.255.0
h323-gateway voip bind srcaddr 192.168.x.x
interface FastEthernet0/0
interface Serial0/0
bandwidth 1544
no ip address
encapsulation frame-relay IETF
priority-group 1
no arp frame-relay
frame-relay lmi-type ansi
interface Serial0/0.1 point-to-point
bandwidth 512
ip address 192.168.x.x 255.255.255.252
traffic-shape group 121 384000 50000 50000 1000
frame-relay interface-dlci 100
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:15
no ip address
ip accounting access-violations
encapsulation hdlc
no logging event link-status
isdn overlap-receiving
isdn incoming-voice voice
isdn bchan-number-order ascending
no fair-queue
no cdp enable
voice-port 1/0:15
dial-peer cor custom
dial-peer voice 6 pots
destination-pattern 6....
dial-peer voice 7 voip
destination-pattern 7...
translate-outgoing called 1
session target ipv4:192.168.X.X
dial-peer voice 2 voip
destination-pattern 2...
dial-peer voice 5 voip
destination-pattern 5...
session target ipv4:192.168.x.x
dial-peer voice 4 voip
destination-pattern 4...
One more thing I suspect is the Encapsulation.. Currently it is HDLC, Should it be PPP?
If the command "sh contro e1 1/0" says always "loss of signal" that means there is a pb between Rx and Tx.
Try this link to make sure the parameters on the Alcatel are correct.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis3600/sw_conf/pbx_int/36a44e1q.pdf
