why does echo canceler make problem ?
cm1231_cisco
Community Member
hi
AS 5350 is connected to the PSTN with E1.
when i call to the PSTN end from IPphone or with the opposite direction and
instantaneously IPphone end speak up, that moment the PSTN end has a listening problem.
the problem was solved, as soon as i did disable the echo canceler fuction.
but surely this time echo problem was come out.
jbayuka
Level 9
Level 9
If echo delay is longer than the provisioned tail length, echo cancellation will not work.
http://www.cisco.com/en/US/products/hw/vcallcon/ps2027/products_installation_guide_chapter09186a00800c1a3a.html#1222556
You can learn more about echo related issues here
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080149a1f.shtml
