07-25-2011 04:41 PM - edited 03-21-2019 04:23 AM
I have 2 different primary service connected to a dual E1 module, I configured both to work individualy, what I would like to do set the second E1 interface to work as a primary for outban calls all the time
my question is is this option works under the clock source line (primary / secondary)
Sam
07-25-2011 04:48 PM
This is a preference set under your outgoing pots dial peer (if you have identical\matching peers) or it can be set as a per user basis by using COR lists. Either way you would probably have to contact support if you are unfamiliar with either concept.
The clock is used between the telco and your device to synchronize the bits because you are using synchronous communications for a typical PRI. That command doesn't specify which T1 to use
07-25-2011 05:27 PM
Hi Sam,
Marcus is onto something there, the way I was thinking which might be a possibility but potentially and uglier way of doing it is as follows:
The issue with this setup is that I am not sure if you can do this with CCA, on a CLI basis you could do it in under an hour with a TXT editor and then copying the configuration over, you just need to make sure you translation profiles/rules are sound, this would be the tricky part as you would no matter what have to apply some form of inbound routing, unless the carrier allows you to present the CLI from the Primary E-1 (Some countries this cannot be done).
Anyway its just a thought, this is how I have done it a few times in the past, maybe SBS can assist you with a clearly defined and CCA supported method.
Cheers,
David.
07-25-2011 07:17 PM
Thanks Guys for the quick response, see below the way how I configured it:
*********** first 100 DID with the 1st Primary Service *********
voice translation-rule 2
rule 3 /^029xxxx2/ /2/
rule 4 /^29xxxx2/ /2/
rule 5 /^9xxxx2/ /2/
voice translation-rule 3
rule 15 /^...$/ /9xxxxx00/
************* Second 200 DID with the 2nd Primary Service **********
voice translation-rule 5
rule 3 /^029xxxx4/ /4/
rule 4 /^29xxxx4/ /4/
rule 5 /^9xxxx4/ /4/
rule 6 /^029xxxx5/ /5/
rule 7 /^29xxxx5/ /5/
rule 8 /^93xxxx5/ /5/
voice translation-rule 6
voice-port 0/0/0:15
translation-profile incoming INDIAL
translation-profile outgoing CALLER_ID
voice-port 0/1/0:15
translation-profile incoming IAD
translation-profile outgoing IAD_ID
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
interface Serial0/1/0:15
description SIP CONNECT
no ip address
encapsulation hdlc
priority-group 1 --(I have added this statement)
no cdp enable
what I am trying to achieve is, any outbound calls go through the second Primary service
also I don't use CCA to configure the System
Cheers
Sam
07-25-2011 08:08 PM
Hi Sam,
Are trying to get this to work with Telstra's SIP-Connect?
I.E You are using an IAD interfacing towards the UC and not a Direct SIP trunk?
Cheers,
David.
07-25-2011 08:44 PM
hi David
yes, we have an existing PRI service and we moved toward the sip connect with Telstra but we are not decommissioning the existing service until end if the year but at mean time I have it working along with the existing service the issue I'm having is caller ID and outbound calls are working with the sip connect but for what ever reason sometime it is going via the existing service
Idont know if that make sence
cheers
Sam
07-25-2011 08:58 PM
Hi Sam,
My guess at this stage is the preference set on the Dial-Peer, the weight needs to be taken into consideration, hence why I had suggested multiple Dial-peers for each one to point to their respective circuit.
I don't know how accurate the priority group command is, and if this command overrides the weighting on the Dial-peers themselves I.E the preferences set on the DP's.
How have you configured the Dial-peers or are they as they were prior to the integration of SIP-Connect?
Cheers,
David.
07-25-2011 09:09 PM
Thanks David,
I think what I will do is remove the priority goup statement and test the dial peers preference that I have already configured,
which is the SIP connect as preference 1 and the PRI preference 2
I will let you know by tomorrow
Cheers
Sam
07-25-2011 10:18 PM
Roger Roger - Sam
Looking forward to your update mate!
Cheers,
David.
07-26-2011 05:59 AM
Hi David,
as I mentioned on my previous reply that I will remove the priority group statement, and go with the DP preferences, I did that this afternoon, and all working the way I wanted
thanks again for your assistance
Cheers
Sam
07-26-2011 02:51 PM
Your welcome
Glad it is working the way you want it to
Cheers,
David.
